No Midi firing of modules
SPEC:
Computer: AMD ATHLON 64 2.4GHz Ram: 2GB System: WIN XP PRO SP2 Software: PT M-POWERED 7.1 Audio Inter: M-AUDIO FIREWIRE 410 Midi Inter: MIDISPORT 8X8/s Controller: ROLAND RS-70 Modules: MOTIF RACK ES, E-MU MO'PHATT 1st let me clarify that I use Ableton 5.0, and Acid Pro 6 using everything up above except PT, and midi works like a charm. I create a new midi track in PT, after enabling "Midi Thru", and doing all the necessary setup in "Midi Studio Setup". I setup the track like so: Input-All / Output-one of the two modules w/appropriate Ch. selected. I get activity in the track meter but neither module will fire. Please keep in mind that the 8x8 works perfectly in all other Apps. I have e-mailed Digidesign and they told me a series of steps to take: Have the latest drivers for FW 410, and 8x8/s. Then make sure that I dump all existing drivers and folders for the FW 410, 8x8/s and PT M-powered 7.1 Then re-install one by one starting with FW 410, 8x8/s and then PT. Open a new session, create a midi track, set the input to all, and record enable the track, then try inputting midi via the 8x8/s, and still I get activity in the track meter, but no modules firing. Some of you guys are pretty knowledgeble so let see if you can figure this one out. Servon
The Truth is constant and never changing! |
Global Midi Offset and USB MIDI Sound Modules | colonyrecords | Pro Tools M-Powered (Win) | 0 | 11-26-2008 08:42 AM |
Midi Firing my Roland XV5050 Global Delay Setting? | ChuckLogan | MIDI | 0 | 12-24-2004 06:49 PM |
can i use my midi sound modules with PTLE? | robert quarless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-03-2003 09:05 AM |
Midi sound Modules!! what do you use? | Blake Henderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 08-02-2002 09:43 AM |
Midi Modules & PT24 Mix | Frank Senior | Pro Tools TDM Systems (Win) | 1 | 07-27-1999 02:38 PM |
