Find Tempo
Is there something in PT 7.4 or 8.0 that resembles the "Find Tempo" function in Digital Performer. I need to calculate a tempo that hits multiple cuts of picture.. When I make identify multiple hit points as the closest downbeat, PT changes the tempo between each marker. I need it to calculate the tempo from the start of the cue. Is that possible?
Thanks
Intel Nehalem 8 Core 2.26 w/10 gigs of Ram 4 internal sata drives (1 terabyte) Magma Pci to PCIe 6 slot chassis PT 8cs3 HD 2 Accel 1 Process Card UAD quad PT 8.0.1 cs 1 OSX 10.5.8 Ctrl 24 |
Re: Find Tempo
Did you place a tempo marking at the top of cue?
Oh, sorry... I see what you're asking. I'm no help.
Brian Steckler, Producer |
Re: Find Tempo
I think Identify Beat is what you're looking for.
Re: Find Tempo
right, just to amplify:
select the start of a measure (by tabbing to transient on the bass drum for example) and separate the region there (Command E), then count to 1 st beat of the next bar (or 2) and do the same thing on THAT downbeat. then select that new region (of 1 or 2 bars exactly) and pull down IDENTIFY BEAT tell it that it's beat one of the bar (example: 3/1/0) and tell it the end point (4/1/0 or 5/1/0) and hit return. it will enter a tempo event with the determined tempo you can remove the region separations, if they bother you, with HEAL SEPARATION
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
Re: Find Tempo
oral roberts would have loved this function
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Re: Find Tempo
Thanks guys... I have gone (and continue to use) the identify beat route, but what I am meaning is:
Can protools calculate a tempo based on multiple hit points. The Identify beat function seems to only do one hit at a time and then calculates a new tempo from the last hit to the next.. EG: tempo set at 120: beat 1 bar 1 is at SMTPE : 01:01:00:00 There is a mark that I need to hit at 01:01:16:22 I know that I can identify that hit as it's nearest downbeat and PT will calculate the tempo based on that.. making the tempo about 123.569 What about the next hit and the one after that.. If I identify another beat after the one that I just made PT will calculate a tempo change from the first hit and NOT Beat 1... What I need is a way to calculate the best tempo to hit multiple marks in a cue while having a consistent tempo.. Digital Performer has an option to calculate the best tempo to hit the most marks at that given calculated tempo.. does PT have anything that will do something close to that? Thanks again for your help....
Re: Find Tempo
I'm having the same issue.
My next approach is going to be finding tempo via hit markers in DP then exporting the tempo map with a standard MIDI file. I was told by a veteran in the field that is the way to do it. |
Re: Find Tempo
Watch my podcast to create a tempo ruler based on a live performance:
http://itunes.apple.com/us/podcast/m...ms/id480494484 What you're asking is a little different, and I think DP is the best choice for it. Last edited by JMDNYC; 12-09-2011 at 11:56 AM. Reason: Read original post more closely |
Re: Find Tempo
a little beat detective... a little identify beat... and a little trial and error should get u there... like my friend told me once if it says 95.897 theres a good chance its 96
Re: Find Tempo
one thing i do to double check is if i know its a consitant tempo thru the whole song i check my loop at the beginning and at the very end... if it loops up good at the beginning and at the end ur probably good and have found the right tempo
Find Tempo? | acq1 | Pro Tools M-Powered (Mac) | 1 | 05-02-2009 01:24 AM |
Can someone help me find Tap Tempo in PT7 LE | JacobIz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-26-2007 11:21 PM |
find tempo of wav????? | Livin' Proof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-31-2007 10:34 PM |
Cant find "tap tempo" function!!!!! | a kremer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-30-2007 04:03 PM |
How can you find out tempo | rcourell1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-06-2005 02:51 PM |
