Invalid soundfile error...
Before I updated to 10.2 (and then to 10.2.2), Pro Tools Free worked fine. A year later, I am having this trouble with 4 audio files.
They were recorded in Coaster, aiff files, mono, 16bit. I have a fifth (smaller file) w/out the problems these larger (500mb) files are having. When I try to convert and import into a 24 bit session, I get the error message: soundfile error: invalid number of bytes (I did not write the error down, so this might not be exactly what it says) When I try to export the audio from a 16 bit session, I get the exact same message. I tried moving the application, my sound files, and the output folder to an external 120 gb firewire hard drive. Still no go. Should I do a full reinstall of the OMS, DAE, and Pro Tools files? This worked a year ago with files just as large! Thanks! |
Re: Invalid soundfile error...
Looks like you could have a corrupt file on your hands.
Try converting it with another app. SoundApp will handle SDII files. If that works then I would try trashing PT prefs. You'll have to reset your prefs, and re-authorize any extra plug-ins you have, but that's easier than re-installing everything which would be a last resort. Just out of curiousity, do you have Jag & OS9 on separate partitions? |
SoundApp you say? Wow. Will do. Good thing I held onto it.
The files play, and I have been able to burn them to CD via iTunes. Jag and 9 are on the same partition. I have trashed the prefs already. |
I converted to a wav, then Pro Tools Free would import and convert that to a wav file. It worked!
Thanks! Now that I went through this, I have this sinking feeling that I had to do this before. This time, however, I had plenty of disk space [img]images/icons/smile.gif[/img] |
Invalid Fade Error | tunes7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-24-2009 09:11 AM |
invalid clock error 002 and ISA 428 | kindkind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 06-16-2007 05:41 AM |
"invalid configuration of Pro Tools" error message | kopf | Pro Tools M-Powered (Mac) | 2 | 07-11-2006 09:10 AM |
Invalid drive error question | ChrisO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-22-2002 11:56 AM |
Soundfile Error: Invalid Number of Bytes | dBgogogo | Pro Tools TDM Systems (Mac) | 1 | 01-17-2001 12:03 AM |
