Artist keeps disconnecting after a while
I have an Artist Mix & Control who keep disconnecting after a while. The tedious process of dialing and enabling Eucon in the peripherals and then restarting Econ applications get them back connected. Any idea how to keep them connected?
Protools 2019.12, HighSierra 10.13.6, 2x2.66 Ghz 6 Core intel Xeon, 24 Gb 1333 MHz DDR3 |
Re: Artist keeps disconnecting after a while
Dont toggle the pref in PT peripheral's it will actually will make things worse, its not meant as a reset just an enable. Are you running a direct cable from the WS to the Mix ? If so try a different cable. If using a router/switch do the same.
When you lose connection is EuControl still responsive, do you see the mix in the surfaces page ? if not try just restarting the Mix. |
Thank you for your quick reply. Both surfaces are connected to a router. Tried different cables to no avail. the Eucontrol app is still responsive and both surfaces still show up in the My surfaces section. But the on the surfaces themselves the sessions track names are gone and it only says Protools 12M on the left side of the screen. Rebooting both surfaces gets me the same result. Only when i toggle enable eucon and then restart Eucon applications, and reboot the surfaces the tracks show up again. When i remove the surfaces in the app, all surfaces disappear, even in the All surfaces section. Thank you for helping out.
Next thing to try is this Clean EUCON I presume you are on v3.6.1 ?
Mbox 3 pro crashing/disconnecting | DoronFarhi | FireWire & USB Audio Interfaces (Win) | 11 | 10-03-2015 10:45 PM |
S5MC disconnecting from PT | Steven1145 | System 5 | 5 | 08-19-2014 02:12 PM |
Eleven Rack Keeps Disconnecting | CliffT | Eleven Rack | 3 | 09-29-2010 02:11 PM |
Digi 003 keeps disconnecting if left for a while. | filmharmonix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-02-2010 04:37 PM |
Direct Connect keeps DisConnecting! | Bryan | Pro Tools TDM Systems (Mac) | 3 | 08-03-2001 07:52 PM |
