Old 09-04-2023, 01:56 PM
alexthemusicbloke alexthemusicbloke is offline
Default Having an issue with 23.6 / changing highlighted plugin
Hey All / Eddie
Hope you're well.
I'm having an issue since I updated to Eucon 23.6. Running PT 23.6 as well.
Whenever the EuCon app is open on my Mac (Monterey 12.5.1 Intel), if I add a plugin on a slot somewhere (with the keyboard/mouse), the plugin will usually flash up briefly only to instantly revert back to showing a previously highlighted plugin.
I can't pinpoint exactly how it's choosing which plugin to take me back to, whether it's the penultimate most recently added plugin, or the previously highlighted one, I can't be sure.
Not a huge issue when it's two different plugins, but for example Pro-Q 3 or Kirchhoff, which are on a lot of channels in a project, it's often resulting in me changing settings for the wrong instance of the plugin in a project.
Have only just tried the PLIST hack you suggested in the pinned thread, I can report back if it's changed the behaviour.
Thanks,
Alex
Old 09-05-2023, 02:59 AM
tope d's Avatar
tope d tope d is online now
Default Re: Having an issue with 23.6 / changing highlighted plugin
Originally Posted by alexthemusicbloke View Post
Hey All / Eddie
Hope you're well.
Thanks,
Alex
Can you post a screenrecording of the issue you’re having?
Checking on this further.
Thanks
-Tope
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 09-05-2023, 03:09 AM
tope d's Avatar
Hey All / Eddie
Hope you're well.
Thanks,
Alex
I’ve started a support case for you under case number 04675512. Tech support team will be in touch through Email.
Thank you,
-Tope
-Tope
www.topedomingo.com
Old 09-05-2023, 09:41 AM
EddieJones's Avatar
Hey All / Eddie
Hope you're well.
Thanks,
Alex
Can you check if the plugin that comes up is from the attentioned track in EUCON?
Old 09-06-2023, 01:44 AM
Thank you,
-Tope
Thanks Tope, I'll check in via email too.
Hmmm, you know I haven't actually put much effort into figuring out exactly what 'logic' it's following when it comes to the previous plugin.
I'll try and suss it today and see if I can get a screen grab. Thanks.
Old 02-13-2024, 03:49 PM
fsavell fsavell is offline
Was this ever resolved?
I'm getting the same problem - random plugins appearing when I either instantiate a new, or option-drag a plugin to a track.
I've recorded a long video to see if I can identify what track they're coming from. Sometimes its the currently selected track, but other times its a track that was selected >3 tracks previously.
Using PT2023.12, Ventura 13.6.3, Eucon 2023.11.0.121 and running an S3.
Also have only selected 'Plugins' in the Attention most recently clicked DAW area, along with Auto-bank to selected track, and S3 Upper Knobs.
Pro Tools Ultimate 2024.10.1, HDX1 • Mac Studio M2 Ultra - macOS 15.1.1
Old 02-13-2024, 04:38 PM
EddieJones's Avatar
I'm pretty sure it is already and will be in the next PT release.
Old 05-30-2024, 04:14 PM
Hey Eddie
I just wanted to report that this issue is still occurring with PT2024.3
Can provide a video if you need.
Forrester
Old 05-30-2024, 05:10 PM
EddieJones's Avatar
Originally Posted by fsavell View Post
Hey Eddie
Forrester
Please do, It doesn't sound normal
Old 06-02-2024, 03:57 PM
Hi Eddie
Video of it here: https://forrestersavell.filemail.com/d/qsgvtlyhrknuxyd
Thanks
Forrester
Vol/Pk/Dly Changing Issue Roulette Records Pro Tools 12 8 01-25-2018 10:31 AM
Bit-Changing Plugin jgiannis Pro Tools 10 1 03-17-2016 11:45 AM
Changing the Plugin Folder BrandonMillerAudio macOS 2 08-30-2014 04:24 AM
Why is a specific plugin highlighted on my Inserts list? PTLExp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-17-2010 08:18 PM
Changing Transport issue butter_lover 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-07-2003 05:27 PM
