Old 10-01-2023, 01:40 PM
Danny Winn Danny Winn is offline
Default Weird Wav Gain problem (No difference)
So I have a small lick in a Guitar Chug/Picked area that I wanted to make louder, so I separated it and increased the gain but it makes no audible difference. (Even at a 20db gain with giant wave)
I've done this a million times but have never encountered this problem,
I restarted the PC and program and recalculated waveform overviews but nothing works. (I also shut off all effects)
Any ideas on what's going on here?
Thanks much!
Latest version of Pro Tools
Windows 11
System i7
64 GBs
Old 10-01-2023, 02:15 PM
Default Re: Weird Wav Gain problem (No difference)
Wav gain? gain? The proper term is clip gain.
The most obvious cause for behavior like this is simply you are not applying the clip gain on a track you are actually listening to. So wonderful easy to make mistakes like that. Use solo or mute to confirm you are indeed hearing the track you are editing. And/or riding the fader should affect what you hear.. does it? And say it's not another track, maybe some complex routing, maybe a hidden track. And make sure you are not applying clip gain to a clip on a playlist, does not look like that in the screenshot.
Other folks have got themselves caught up with clip gain not working as expected if Melodyne is being used on a track.
Failing those it's maybe session corruption, try importing just the audio from that track into a new totally empty session and see if that works OK.
Old 10-01-2023, 02:40 PM
BScout BScout is offline
Highlight the clip and then go to Edit > Automation > "convert clip gain to volume automation" as a test. Make sure the track is in read automation. See if you hear it. If you don't, you are monitoring the wrong track while thinking you are listening to the one you are editing.
Happens to the best of us.
Pro Tools Ult 2023.9, HDX 3, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, FireHD x 2, Dock, iPad Mac Mini 14,12, 12 core, macOS 13.6.1RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 10-01-2023, 03:17 PM
Thanks for your response, I will try all that when I open the session later today. Appreciate it!
Old 10-01-2023, 04:35 PM
Top Jimmy's Avatar
Any chance you transferred the audio into the melodyne plugin?
James Cadwallader
Old 10-01-2023, 05:02 PM
No chance, I never set Melodyne up or ever use it. Thanks!!!
Old 10-01-2023, 05:24 PM
So I figured it out and it was really stupid.
I'm using an Amp sim plugin with slight distortion and it wouldn't affect that Wav area until I committed all plugins. Duh.
Thanks for you're input!
Old 10-01-2023, 05:25 PM
Old 10-01-2023, 05:37 PM
Great you got it sorted. These things can be frustrating. Sometimes it just takes walking away for while, sometimes the determination to think of tests for what might be going wrong, and other times asking others for help.
Normalize VS Gain - is there a difference? QuacksMeUp AAX Plug-ins 2 08-08-2022 04:07 PM
Gain difference between Profile/ SC48 and S6 louderock VENUE Live Sound Systems 4 09-26-2018 07:03 AM
What's the difference between clip gain and volume automation on audio? rockguitarist1255 Pro Tools 10 7 12-27-2012 08:20 PM
Gain Difference On Live and Recording Board? SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-20-2006 10:01 AM
Weird M-Box Preamp Gain .:*Robot Boy*:. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-08-2005 05:42 AM
