Re: Freezing A Folder Track Does Not Freeze Its Contents
It should freeze whatever output there is on the folder. Tracks that won't contribute to the output are not included obviously. And individual tracks are not frozen, only the output of the folder.
Just think a minute about a drum kit AUX. You are freezing the kit aux output, not kit tracks.
Now picture a scenario where you are nearing a mix, and your session is heavily loaded with tracks and plugins. All your drums, guitars, keys, vocals are neatly stacked into folders. But you have to do a couple of overdubs, so you want to freeze most of the session and go back to a 64 buffer setting to reduce your CPU load and lessen latency. Of course, you could bounce the whole thing down to stereo for your overdubs. But freezing tracks is also a solid way to do it. I face situations like that very often during production. Would it not be a time-saver to just freeze the folders and have most of your tracks and plugins frozen? You can always unfreeze after your overdubs so you can mix. You are not wrong, bro, about routing folders being glorified auxes. But folder tracks could be much more than what they are now, and having the option to do more doesn't break anything.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Once you have frozen your folder, just keep that audio and make the folder and its tracks inactive.
My point is, does it break anything to have that quick option?
Possibly. Because it would need to be implemented and tested, and there is no guarantee that change would not break something else somewhere else, so I would just take those few extra clicks. Your productivity is between your ears, not clicking the mouse.
#16
I'd vote for this. This is how I imagined it would work too, or at least have it as an option
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control http://www.lostboysstudio.com |
#17
That would also remove the option of having a track in a folder that is not routed to its output
#18
I started out with tape and consoles, but we are now in a digital workflow, where the old routing limitations don't have to hold. I'm not saying this just for the argument's sake; I sincerely see such enhancements as improvements.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins Last edited by lesbrunn; 05-07-2020 at 02:46 PM. |
#19
Hey JFreak, what do you think is the best way to suggest this to Avid? Does idea-scale still exist? Not that it worked very well before...I'd definitely vote even if the suggestion came from someone else.
#20
Maybe the folder track feature requests thread that is made sticky?
Track freeze is freezing too much | SigFriedChicken | Pro Tools 12 | 9 | 12-14-2021 06:24 AM |
"Obtaining folder contents" task | Bydy | Pro Tools 12 | 1 | 01-26-2021 02:14 PM |
Calculating Waveforms and Synchronizing Folder Contents randomly | BrianJArmstrong | macOS | 7 | 01-27-2019 08:07 AM |
Freeze without Freezing Inserts - Feature request? | Dizzi45Z | Pro Tools 2018 | 4 | 08-04-2018 04:32 AM |
Task Manager , "Obtain folder contents" , "Expanding Tree" ??? | joachim | Tips & Tricks | 0 | 06-15-2015 11:10 AM |
