Old 12-15-2011, 11:30 PM
Ale Ale is offline
Default Waves expensive TDM route absolete in future?
Hi
I thought about getting some updates for my current V7 Waves bundles..
As I understand future aax plugins are the same for the new dsp chips and native.
So thereis no need to buy TDM versions anymore?
Just wondering
Alex
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 12-16-2011, 01:03 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Waves expensive TDM route absolete in future?
All depends on $.
My TDM upgrade was less than going native. This also gives me native and likewise will likely (in the near future) continue as DSP/Native.
AAX coding may or may not address both processes.
However, If you plan on keeping or expanding TDM systems.....
Old 12-16-2011, 01:40 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by Ale View Post
Hi
Just wondering
Alex
AAX will come in DSP or Native or in some cases both. I imagine Waves will continue to supply both and if you buy the DSP versions you will also get the Native versions.
I personally would want as many plugins as possible running as DSP versions, leaving the computer CPU/Native free for those plugs/processes that need it.
So yes to me there is still an advantage in buying the DSP versions
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-16-2011, 02:44 AM
Ale Ale is offline
Default Re: Waves expensive TDM route obsolete in future?
OK.
I thought aax will automatically run native or dsp if a hdx is available.
But i still do not see, that there is extra coding work to do for aax plugs.
There should be no need to keep that high prices. Who knows!
But for sute staying tdm/dsp you get the whole world
Ale
Old 12-16-2011, 06:34 AM
crizdee's Avatar
OK.
Ale
Although it is easier to code for both with AAX it still requires extra coding time for the DSP version. Utilising the HDX chips has always been more time consuming than just coding for native.
Some vendors have already announce their prices and the DSP versions are still considerably more expensive!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-16-2011, 10:26 AM
Drew Mazurek's Avatar
Chris
Link?
www.drewmazurek.com
Old 12-16-2011, 11:12 AM
crizdee's Avatar
Originally Posted by dmazurek View Post
Link?
Well Sonnox for a start, considerably more expensive for AAX DSP...
http://www.sonnoxplugins.com/pub/plu.../AAX_faq.htm#3
From what i've read others are still going to be charging more for the DSP versions.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-16-2011, 11:30 AM
Craig F Craig F is offline
Other than Sonnox all I have seen is very reasonable (free to a very minimal cost)
Waves will probably get up by raising WUP's prices
So who eles is charging a lot for AAX?
Thank you,
Craig
Old 12-16-2011, 11:57 AM
crizdee's Avatar
Its the difference in pricing between AAX DSP and AAX Native that were talking about. and i'll be surprised if that price difference remains with AAX versions as it did with TDM and Native.
From what i've seen so far vendors still see the AAX DSP versions as a more costly option.
Chris
Producer, Engineer,
www.ukmastering.com
Waves WNS TDM less expensive then Native Brandonx1 Post - Surround - Video 1 11-21-2009 05:18 PM
Does This seem expensive to you? funeral 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-20-2007 10:17 AM
Least Expensive was to get into TDM PhatBit Pro Tools TDM Systems (Mac) 22 06-03-2005 02:41 AM
Least Expensive Reliable HD Mondoslug1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-06-2003 05:30 PM
Which is more expensive? Sudsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-10-2001 10:52 PM
