Old 09-19-2011, 04:43 PM
KenRyan KenRyan is offline
Default Rendering Audio Question
I'm new to Pro Tools but not to audio recording. I just started today with Pro tools SE that came with my Fast Track Pro interface. I recorded a voiceover track and was trying to render/mix it down for use outside of PT. It was just a 3-minute audio. I assumed that Exporting was what I was supposed to do, so I did that and it took the entire 3 minutes of the audio to render.
Is that right? Surely not. It takes like 5 seconds to render that in Reaper. What am I doing wrong?
Thanks!
Ken
ps- I'm open to suggestions as to how to take the plunge into Pro Tools beyond the SE version I have (on my XP system). Advice?
-K
Old 09-19-2011, 05:32 PM
Top Jimmy's Avatar
Default Re: Rendering Audio Question
Welcome to Pro Tools. You've just discovered that bouncing is done in real-time. Yes, there has been a lot of griping about this fact over the years.
You can actually export your audio faster if all you have is a single track. Record your audio, edit as desired, apply audiosuite processes as desired, export final region from regions bin menu.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 09-20-2011, 07:25 AM
Thanks Jimmy!
Ken
Rendering midi to audio Cal D Windows 12 02-07-2016 08:21 AM
Audio gain not rendering MarkWorsnop Pro Tools 10 3 03-10-2013 02:59 PM
Rendering Elastic Audio Swagstaff Pro Tools SE and Essential (Win) 0 10-17-2012 04:55 PM
Elastic Audio not rendering ALL REGIONS Kourquie Pro Tools TDM Systems (Mac) 1 10-04-2010 10:26 AM
Elastic audio rendering solution bterry343 Tips & Tricks 0 02-19-2009 12:56 PM
