Pro Tools 10.3.8 Driver/DIGI 002 Finale 2012 problem SOLVED!
Pro Tools 10.3.8.378, Finale 2014 and Finale 2011 all run fine with no odd crashes.
However, when I boot up Finale 2012, it crashes, and the crash log cites DIDI 002 as a problem. I am running: Mac OS X 10.85 Pro Tools 10.3.8.378 Pro Tools Drivers 10.3.3 Finale 2012c.r13 And of course…Pro Tools is not booted up at this time. I have no other programs open while I am booting Finale 2012. Questions: 1. Am using the latest Drivers for Pro Tools 10.3.8.378? If not, where can I find them as I can only locate a Download for Drivers 10.3.3? 2. Is this a problem with the Drivers, or is this a Finale 2012 problem? Dan Last edited by DanielZ; 04-16-2014 at 03:48 PM. |
Re: Pro Tools 10.3.8 Driver/DIGI 002 Finale 2012 problem
Could you please post the data from the crashed thread in the crash log?
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
I am using the DIGI 002 as the Playback Device.
The Crash File is quite big so I broke it into two parts. Crash Log is attached. Thanks, Dan |
What happens if you use something else as the playback device?
Apple code is being executed when the crash occurs.
I don't see any way I can change Playback Devices for Finale 2012.
Inside of Finale 2012 I have the Audio device [Playback Engine] set for DIGI 002. If the program always crashes upon boot-up then I can never get "inside" to change the Audio device [Playback Engine,] even if I change my Audio In/Out source in my Mac System Prefs. Dan |
If you disconnect the DIGI 002 and launch Finale, does it crash? If not, that would be your opportunity to change the Audio device to Built-In, quit, connect the DIGI 002, and launch Finale again to see if the mere presence of the DIGI 002 is causing the crash.
That solved that. I disconnected the DIGI 002 and Finale 2012 fired up perfectly.
I created a New Document in Finale 2012 and started working—all was normal. I Shut Down the computer, reconnected and turned ON the DIGI 002, re-Started my computer, booted up Finale 2012—and Crash!. So…the DIGI 002 is causing the problems. Do know that before I Upgraded to Pro Tools 10.3.8.378, Finale 2012 worked like a charm, for three years—all the ska computer, the DIGI 002, and everything else. Where do I go from here? Many thanks for you time and work, Dan |
There are two paths to take now. One is to open a ticket with whoever makes Finale, the other is to open an Avid Support Case (ASC) with Avid. I will bring this thread to the attention of the super-mods. That's all I can offer at this point.
Digi 002 and 003 Drivers Linked from the main drivers page: www.avid.com/drivers |
digi 003 audio driver problem | evon | Pro Tools 10 | 0 | 12-02-2013 06:30 AM |
Pro Tools 8.0.4 with Aria Player Plugins Finale 2012 | FrankCan | Pro Tools 10 | 2 | 08-06-2013 05:44 PM |
Pro Tools 9.0.6 and Finale 2011c Midi problem | John335 | Pro Tools 9 | 0 | 02-09-2012 07:17 PM |
Finale-Digi Sound Driver glitch | johnimholz | General Discussion | 1 | 12-08-2008 07:17 AM |
pro tools 5.3.1 xp problem with digi 001 driver | LadyElectrikStudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-18-2004 02:07 PM |
