Re: Building Orchestral Template, but PT Hangs
How many instruments are you loading like?
I think at the minute everyone wants to have a cool template with everything loaded always and it's kind of stupid really.. My current approach, which uses folder tracks, is kind of modular.. I've all my libraries saved as routed folders track presets, so say I want to use CSS for strings and Hollywood brass, I load up those two folders..Generally just using keyswitches or a couple of extra midi tracks or whatever that's all configured ready to go.. If I need any extra particular articulation or whatever I load that up inside the folder, but this is the backbone.. I've all my different libraries saved as folders, as well as a sketching folder, and maybe an effects folder, and just load up whatever when I load a new project.. You can also bang a different template together in 5 minutes.. |
BTW, Michael, are you using the newer M.2 NVMe SSD's? You probably are aware that they are much faster than the older SATA SSD's.
Pretty sure of that. He is using the ridiculously overpriced new cheesegrater which has M.2 built-in and possibility to add more with PCI-express cards. Even with this older 2013 trashcan that I am using M.2 NVMe is the way to go, you need to be using 2012 or older mac pro to have SATA bays
JFreak,
There are a lot of PCIe cards which hold the SATA SSD's that pop right into a new Mac Pro. Michael, I'm using a new Mac Pro with the full 8TB of internal storage. I wonder if it would behave any differently from yours if your storage is PCIe cards? If you'd ever like to test such a question, you could send me a huge template using only Spitfire libraries (I own most of them) and we could compare. |
#16
I've worked with PT on and off since '94, and exclusively since 2005. I can usually make it do what I need, but I am tired of fighting it on some things (which I am sure I will eb doing no matter the machine or software). |
#17
I’m also on the new 16 core Mac Pro now with 384GB RAM, Sonnet M.2 4x4 PCIe card with 4x 2TB Samsungs. Initially I experimented with loading my template within PT but even with super fast storage, loading took too long. PT seems really slow at instantiating Kontakt. I get a dialogue box that says “converting”. The AU version in VE Pro instantiates far faster. I’ve tried loading my template with instrument tracks deactivated and also tried pulling instruments in using PT track presets when needed but in the end I’ve gone back to using VE Pro on the same Mac. No need for sample server PCs anymore! In VE Pro I have pretty much all the Spitfire orchestral libraries loaded with two mic positions of everything and lots of other libraries too. Even with the Sonnet NVMe adapter card, it’s still taking minutes to load the template. Too long to reload every time PT crashes or I open/create another session. Even in VE Pro, the template appears to finish loading but Kontakt is still pulling in samples in the background for a while. Can’t comment on Orchestra Tools in Kontakt because I’m using their SINE player.
Dave Marsden UK |
#18
I think Kontakt is VST in a wrapper, sadly. When I install AAX Kontakt only, it stores a .vst as well and if the .vst is removed Kontakt is not starting
#19
That wouldn’t surprise me. It might explain the “converting” dialog when Kontakt instantiates.
Dave Marsden UK |
#20
Would be great if NI got their act together
Anyone here using PT 12 for orchestral work (big template) | vudoo | Pro Tools 12 | 5 | 01-13-2017 05:28 AM |
Orchestral Template | KierONeil | General Discussion | 1 | 06-26-2015 02:46 PM |
PT8CS2 Hangs on Building "Miscellaneous Views" whatever that means | 25ghosts | Pro Tools TDM Systems (Mac) | 5 | 03-02-2009 03:21 PM |
Orchestral VIs | SixChurchStreet | Virtual Instruments | 1 | 01-05-2009 04:21 PM |
Using orchestral samples | vogue | Tips & Tricks | 3 | 02-26-2004 03:46 AM |
