Old 11-09-2007, 09:35 PM
lwilliam lwilliam is offline
Default Adding EA to existing 7.3 sessions?
Has anyone tried adding an EA track to an existing 7.3 session?
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 11-09-2007, 10:27 PM
Default Re: Adding EA to existing 7.3 sessions?
Just open the session in 7.4 and enable EA on the track(s). If you have been using sd2 files, Save Copy In... and convert to a real file format
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-10-2007, 12:45 AM
Thanks. That's good info.
My sessions normally open with aif files...I'm just seeing what the "gotcha's" may be before I download and install over a pretty stable system.
Larry
Old 11-10-2007, 03:53 AM
TCDet TCDet is offline
? 7.4 to 7.3 prep.
In 7.4 when you de activate EA you get a choice to commit or restore.
So when finished commit your EA and free up some resources or before going to a studio with 7.3. If EA is on and you open in 7.3 you'll loose your EA edits.
(There is no save copy to V-7.3) 7.4 can be opened by 7.3 Pro Tools.
TC
Old 11-11-2007, 07:17 PM
waves3 waves3 is offline
Hi, I was just getting ready to give people the heads up on this, and discovered this thread, you beat me to it. Is this posted anywhere, that EA won't do SD2 files? This had me going nuts, I tried everything, and then stumbled upon it, did a Save Copy in, converted to wave and all was fine, even had tech support stumped.
David
Old 11-11-2007, 07:45 PM
Yes, it's in the Pro Tools 7.4 Reference Guide.
Rail
Platinum Samples
Old 11-12-2007, 04:50 AM
Ray Campbell Ray Campbell is offline
? 7.4 to 7.3 prep.
So what happens when you do a "Save Copy As..." to save as a PT6 session when you have EA tracks?
Ray
Old 11-12-2007, 09:31 AM
Prep the same way. Any version prior to 7.4 will not understand EA!
Help-adding first PCI Accel card to pre-existing PCI HD3 system Armando Pro Tools TDM Systems (Mac) 4 05-09-2012 04:49 PM
adding drums on an existing midi track aehn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2010 10:20 AM
Adding accel card to existing system colin1 Pro Tools TDM Systems (Mac) 2 10-04-2006 11:23 PM
adding to an existing audio track keysmia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-27-2004 01:51 PM
Is there a shortcut for adding or deleting tracks from existing track groups? melodymanpop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-13-2001 11:31 PM
