#61
Re: Pro Tools 2022.9 "Saving ARA Data"
Yes, it's more trouble than it's worth in its current incarnation. I'm sure they'll iron it out eventually but maybe they should have ironed it out before public release? The feature shows promise.
#62
When a new feature is unusable because of basic operational issues that is a bug…or an improperly implemented feature. Either way, this is not the way a industry leading company should release major, well publicized, eagerly anticipated, new features. This has to be embarrassing for AVID.
Luna 1.5.5, Logic Pro 10.8.1/Logic Pro 10.7.9, Cubase Pro 13.0.30, Studio One Pro 6.6, Pro Tools Studio 2024.3.1, PreSonus Quantum 2, UA-2 Software 11.2, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo FW 25, USB FW 1.15 and Axe-Edit III 1.13.19, Studio A: Apple iMac 2020, i7 8-core 3.8 GHz, 64 GB RAM, 1 TB SSD, RP5700XT GPU, 10 Gb/s Ethernet, MacOS Ventura 13.6.6. Studio B: Apple iMac 2015, i7 4-core 4 GHz, 64 GB RAM, 1 TB SSD, RP395X GPU, 1 Gb/s Ethernet, MacOS Monterey 12.7.1. |
#63
Did some overdubs today with the old ARA joy. That was a laugh.
#64
An interesting aside... as illogical as this may sound, I'm getting far fewer artifacts from Melodyne edits compared to working the old way. This could be due to various factors, including the fact that I would occasionally use elastic audio before or after Melodyne. Anything to get the job done. An example of this is something I'm currently working on. I did extensive Melodyne editing on the lead vocal because both pitch and time were recorded sloppily. Rephrasing some of the lines called for extreme time correction sometimes, and the results were not always acceptable due to artifacts. Revisiting this vocal using ARA has been amazing! I've made exactly the same pitch and time corrections, and the difference in quality is really something to talk about! Clean, natural, and artifact-free. What I like most is the freedom to edit clips simultaneously and seamlessly in both PT and Melodyne. Yes, PT ARA is still in its infancy and is not perfect, but believe me, there's a lot to say for it here.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins Last edited by lesbrunn; 10-05-2022 at 07:34 PM. |
#65
Is there a way to completely remove melodyne other than restoring the project from a backup?
The "Saving ARA data" is completely killing my workflow. It happens on save but also almost every time when I stop the transport. Even after I committed (rendered) all melodyne audio, "Saving ARA data" is still popping up every other minute. If that helps, here are my specs: Mac Mini 2020 3,2 GHz 6-Core Intel Core i7, 32 GB macOS Monterey 12.6 with the latest updates Pro Tools Studio 2022.09 Melodyne Assistant 5.3.0.011 |
#66
Even though I'm not getting the pop-up, I suspect ARA is constantly working in the background, because I do get constant little stalls that I never had in 22.7.
I agree this release must be embarrassing for Avid. But here's the thing: they bring out these unfinished releases all the time. Do they even get embarrassed? I do hope they'll straighten this thing out soon, though, together with the MIDI.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#67
same here with the constant ARA saving interruptions.
PT HDX mac studio 12.5.1 what a bummer. please fix this avid. it is unusable. |
#68
Yes, I'm getting it as well.
Mac Studio, Monterey 12.5.1 I don't want to turn off the auto-save feature but I may try it and see if it helps.
. System info https://duc.avid.com/member.php?u=57185 "please stop OVER-complicating simple things" |
#69
So after spending a few hours on a 13 min live performance doing doing a ton of edits with Melodyne ARA my workflow bogged way down. I did a 'save as' and removed the melodyned tracks and audio (not deleted from disk, just from audio bin). When I went back to the previously saved version all the ARA data was lost. !@%!%$. Where is the ARA data being saved if not in the session file? What did I do wrong?
WARNING WARNING WARNING. Ug ... lesson learned. Hours lost.
http://www.ainsliegrosser.com/ MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio |
#70
Same issue for me. I'd rather spend the time importing audio into Melodyne the old fashion way then be constantly interrupted. I could manage my time and workflow more efficiently.
Also happening every time I "save" or "save as" I like what we're shooting for with the integration but currently it wastes more time which gets really annoying when you have a lot of work to do. my specs: Mac Studio (2022), Apple M1 Ultra, 64 GB Memory OS Monterey 12.6 Pro Tools 2022.9 Melodyne Studio 5.3.0.011 |
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? | ZerglingPhilosophy | Getting Started | 1 | 09-02-2022 03:43 PM |
"Error, missing PACE authorization" with PT 2022.4 and iLok USB Key [FIXED 5/27] | DaveGross | Pro Tools | 56 | 05-27-2022 09:05 AM |
Pro Tools not importing volume with "import session data" | lapieuvre | Pro Tools 12 | 4 | 10-16-2015 06:02 PM |
Import session data... please break out "plug in settings" and "plug in automation" | yeloocevad | Pro Tools TDM Systems (Mac) | 19 | 10-05-2011 01:04 PM |
Pro Tools LE and "Import Session Data"? | lydpik | Tips & Tricks | 5 | 09-11-2009 05:12 PM |
