Old 12-05-2022, 07:08 AM
seanmccoy seanmccoy is offline
Default Re: Cleaning Up Webcam / Zoom Audio
+1 for the Zynaptiq tools.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 12-11-2022, 07:08 PM
lucienpalmer lucienpalmer is offline
RX has a new tool to rebuild missing frequencies in data compressed audio. I'm using it a ton on a doc feature right now. I would remove any unwanted verb, then unwanted noises, then rebuild missing higher frequencies, then smooth with EQ.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 12-11-2022, 09:17 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Regarding the "juggling act" between noise being present or noise reduction artifacts being present...
I work on a podcast where the audio comes from many sources, sometimes outside, etc. We developed a principle for dealing with problem audio.
For starters, our main host's audio setup is good enough quality, and anything she says can be re-recorded if necessary. That's great. But then, the contrast is so intensely obvious between the "field" audio, coming from Zoom and cell phones etc.
Because the contrast is so obvious, and the actual equalization between the main host and the other interviewees is so impossible, the primary concerns we decided to have were things like phonetic legibility. While legibility is obvious and necessary in most speech editing, simply trying to "clean" it up can lead to different, and I would argue sometimes better, mix choices than trying to make it sound pristine.
In some cases, the fact is that nearly everybody is now more used to hearing multiple audio quality on varied platforms, whatever happened between TV being the main gig in 1990s and the internet really taking off in 2000s... By now, it's simply OK in many cases to de-emphasize the artifacts but accept more of them too.
Not to say don't try to clean things up, but I would hope a webcam mic isn't actually needed in a feature documentary or blockbuster. As one has 'Gotta work with what you have', gotta consider all the differing costs and levels of technical proficiency.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
HTML code is On
Audio Zoom In and Audio Zoom Out Shortcut Jperkins Pro Tools 2018 13 02-15-2018 09:39 AM
When using Quartet with webcam/core audio, all input/output volumes go to max. Dallas Taylor Pro Tools | Duet & Pro Tools | Quartet 0 03-11-2016 11:37 AM
need help cleaning up audio for movie hoodleehoo General Discussion 5 04-27-2011 08:27 AM
cleaning audio bbob Pro Tools TDM Systems (Mac) 6 06-27-2005 10:02 AM
cleaning audio disk of un-used audio files a-sphere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-28-2002 05:18 PM
