Re: unable to locate M-Audio hardware. Make sure your hardware is connected and turne
do you have the lastest cs updates?
i had the same problem with a profire 26262 but a cs update worked for me.
www.myspace.com/stephenpalfreyman |
well, I downloaded all the updates and still nothin. I do think I have hot plugged before, and since I only have one firewire port on my computer, does that mean I have to either get a new port installed, or a new interface all together?
My knowledge on this subject is limited but from what I understand it could damage either the port on your m audio unit, or the port on your computer, or both. Just because you have hot plugged doesn't mean you damaged anything, it just means it's possible. I'd get it checked out. In the event that one or both ports are damaged it should be as simple as replacing the port(s), not the whole unit(s). Correct me if I'm wrong, anyone.
----I was thinking of taking a solo in the bridge. -Nah, I don't think that would sound good. ----Ok, well how about just a series of cool riffs? Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK |
Is there any way you can test your M-Audio interface on another computer, to determine if it's the interface itself that's not recognized, or if it's your computer that's having problems?
'Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o | roland342 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-29-2012 09:01 AM |
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o | MerryD | Pro Tools SE and Essential (Win) | 8 | 08-02-2012 12:59 AM |
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on. | qillster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-09-2011 06:49 PM |
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on.. | qillster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-31-2011 09:08 PM |
Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on | ytass | Pro Tools M-Powered (Win) | 4 | 11-25-2009 12:49 PM |
