Using smart pan pro for surround mixing on pro control
Can anybody suggest a better way to use smart pan pro to do a surround mixing on pro control as you loose the control over the faders of pro control once you attach the panner on to the channel strip-the software fader only controls the level.So the automation&finer fader control goes out of hand.
------------------ taps
taps |
Re: Using smart pan pro for surround mixing on pro control
Hi Taps
You DO have the "Link" button on your SmartPan Panner lit, don't you? This lets you use the ProTools or ProControl faders as you normally would, and the SmartPan fader is linked to the ProTools/ProControl fader. Also, I never have "Input Gain" automation-enabled , as it tends to freak out from time to time and let the track go thru at full level. Hope this helps, good luck! ------------------ Joe Milner Puget Sound Los Angeles [This message has been edited by JKD99 (edited December 21, 2000).] |
Hi Taps,
make shure that you have the laterst Upgrade from KOL. I had the same problems but solved them by the latest upgrade. Marco
MJR |
Suggested Approaches for 5.1 Surround Mixing in Pro Tools 10 with CPTK, C24 control | kat768 | Pro Tools 10 | 0 | 11-27-2013 07:28 AM |
5.1 surround mixing in PT LE!!! | pcmusicpro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-18-2008 02:01 PM |
HUI Surround Mixing | studioalaluna | Post - Surround - Video | 2 | 04-29-2005 09:00 AM |
surround mixing | misterjay | Post - Surround - Video | 1 | 12-19-2004 07:58 PM |
smart pan vs. digi surround mixer? | anders | Tips & Tricks | 0 | 10-15-2001 09:10 AM |
