Clip problem
Hello, need advice pls. How to control / reduce clip height in a PT track. I can reduce the height by volume control, but then volume go down. Some of the tracks in a session suddenly starting to look like this. I post a photo below.
Re: Clip problem
You can also check short cuts for track height at https://youtu.be/i9rXvIeHoso?si=ur8irFK4EjmB0A2C
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
Re: Clip problem
Thanks for info.
Maybe I do not understand or express myself unclear. But problem is the "sound clip" inside the track which is "above the roof". Not the size of the track itself. Need to bring the clips down, but not be reducing volume. Maybe something about saving the session not correct? |
Re: Clip problem
But it is not this point you mean? |
Re: Clip problem
Have you tried using the waveform zoom control?
Re: Clip problem
Re: Clip problem
The waveform zoom control solved my problem.
Thanks so much for all inputs -:) |
Re: Clip problem
Oh,
Do you mean the waveform height? If on Windows, Have you tried hitting Alt+shift+scroll?
Re: Clip problem
I am on Mac.
Thanks for your support anyway. |
Re: Clip problem
Something else that might be helpful: related shortcuts. You can adjust the height of the waveforms by clicking and dragging on the audio zoom icon (see my earlier post) or by using Command + Option + [ to zoom out vertically (or Command + Option + ] to zoom in vertically. Helps speed up the work :)
Selecting a clip in Edit window fails to select clip in Clip List | oldskool | Pro Tools 2020 | 8 | 09-28-2021 01:43 AM |
Nudging a clip past another clip removes the stationary clip | evil.beasts | Pro Tools TDM Systems (Mac) | 0 | 11-01-2017 11:08 AM |
Clip editing problem ! | stratevcaster | Pro Tools 10 | 14 | 02-26-2013 09:03 PM |
problem with 192 clip | bonfi64 | Pro Tools TDM Systems (Mac) | 0 | 02-28-2011 05:59 PM |
Clip problem, please help!! | quisco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 03-16-2000 06:10 AM |
