  #31
Old 08-02-2024, 11:31 AM
Panacci Panacci is offline
Default Re: Bug: Commit, Freeze Crashes Constantly 2024.6
Yeah I am getting crashes with IvoryIII and Ivory II with the latest PT. They work fine in DP 11. Been in contact with the Ivory gang and sent them crash logs. I had created a post here but thought I would chime in in this one.
2013 Trashcan w/Monterey. 64 gigs of Ram. 2009, 8 Core Mac 5.1, (32 gigs Ram),2012 MacPro w/Monterey. MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.6 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com
  #32
Old 08-13-2024, 06:02 AM
Kaneepa Kaneepa is offline
Having the same exact problem, and just writing to confirm that if I simply "make inactive" Keyscape I can commit all the other VIs!
I emailed Spectrasonics asking for the beta.
Thanks guys!
  #33
Old 08-13-2024, 06:13 AM
Quick update, THE VERTICAL PIANO by The CrowHill company is creating the same problem as Keyscape by Spectrasonics.
  #34
Old 08-14-2024, 02:48 AM
KlangKraft KlangKraft is offline
also having lots of crashes with 2024.6. Currently not possible to roll back due to ARA.
Spectrasonics support sent me a beta. Things look significantly better until now.
Just spitballin': Almost all of the mentioned "problematic" plugins seem to be VI's with internal sample loading. Maybe there's a conflict going on in PT 2024.6 between it's own "audio loading" vs parallel "audio loading" in plugins? I have no idea though; this is just an observation.
klangkraft.jetzt
Mac Pro 14.8, Sequoia 15.5, Pro Tools HDX 2025.6
  #35
Old 08-16-2024, 10:37 AM
Dizzi45Z Dizzi45Z is offline
Just to make this super clear...
My findings were that I was having issues with almost all virtual instruments and many plugins (such as Eleven) when I had Spectrasonics plugins enabled in my session. Once I got the beta update, the problem went away across all virtual instruments and plugins.
I mention this because it might be easy to blame another plugin vendor since it is happening to the track their product is on, when in reality, it is the fact that you have a Spectrasonics plugin on one of your tracks that is causing this issue with many of your other VI's plugins.
The Beta update I got has been great for a couple weeks now.
Pro Tools HDX 2024.10.2
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 13.6.7
Noisebox Studios -Utah Recording Studio
  #36
Old 08-19-2024, 10:08 AM
marianna's Avatar
marianna marianna is offline
Originally Posted by emgexclusive View Post
Having the same problem, mainly AAE -9173. Running the same specs on Ultimate with HDX Magma Chassis on Ventura 13.6.7 Please give insight, problems been imminent amongst all versions since last December
MacBook Pro 16 inch 2019 2.3GHZ 8 Core Intel
Spectrasonics fixed their issue in a new release which some users tested in beta and it resolved the issue. Their new version so far is flawless .....
Avid has an overall fix coming and the fix we did can also affect other plugins, since it is in a very central place for example the following is fixed in the next version:
PT-325050: Omnisphere in session with certain modulation wheel data causes crash when offline committing other VI (macOS)
HTH peeps
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
  #37
Old 08-20-2024, 01:06 AM
Still having lots of random crashes (during editing, moving tracks, opening any plugins...); even with the Spectrasonics Update.
Opened case 04848049 last week.
Hope this gets resolved with the upcoming Pro Tools version.
klangkraft.jetzt
  #38
Old 08-20-2024, 01:39 AM
Actionmusic Actionmusic is offline
@klangkraft, see if you're using Shaperbox 3.5.2 (3.5.1 seemed ok) or multiple Xfer Serums in the session, these two have been seen as potentially problematic although I haven't been able to reproduce crashes as yet.
That's my Omnisphere bug above - PT-325050: so great that's been sorted thanks, I was able to create a test for that one
  #39
Old 08-20-2024, 02:00 AM
@Actionmusic thank you for the heads up.
Yes two Serums. Going to freeze them to see if that makes a difference.
klangkraft.jetzt
  #40
Old 08-20-2024, 05:32 AM
marianna's Avatar
@actionmusic - thanks for the info.
@KlangKraft - please let me know if the suggestion works.
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
Avid Link constantly installing GrooveCell and SynthCell 2024.1 off the wall macOS 6 01-30-2024 03:07 PM
Commit / Freeze / Rendering Tracks causing Pro Tools to freeze or crash iamkimosabi Pro Tools 2020 11 09-02-2023 09:09 AM
Freeze vs Commit Mixmaster Rick Pro Tools 37 06-08-2023 10:24 AM
Commit/Freeze or something else? joeydego Pro Tools 2018 4 09-03-2018 02:24 PM
Vacuum VI won't Freeze or Commit? Bushpig Pro Tools 12 8 12-24-2016 11:52 PM
