Old 04-03-2011, 02:35 AM
stump stump is offline
Default What should I do with this Miroslav Philharmonik-problem?
I have Miroslav Philharmonik. it worked out fine with PT7, but when I upgraded to 8, it started giving me DAE error number 7401. It works out fine, however, if I run PT with administrative rights. But as I do that, it uses a tremendous amount of CPU power and I can play maybe 20 midi notes and the recording stops.
So, two parter: 1) if it is possible, what can I do that I wouldn't have to run pro tools with admin rights in order to use this plugin?
2)if it's not possible, what changes do I need to make to the engine settings to make the cpu usage more humane?
I thank you in advance, this forum has helped me lot of times already :)
Old 04-03-2011, 09:09 AM
SKI's Avatar
SKI SKI is offline
Default Re: What should I do with this Miroslav Philharmonik-problem?
Make sure your Miraslov is 8 compatible.
Are you running Windows 7?
URBAN MUSIC-
(Hip Hop and R&B)
Old 04-03-2011, 10:16 AM
TOM@METRO's Avatar
Have you tried running it in Reaper ReWired to Pro Tools? This is a far more stable way to run 3rd party VIs until PT becomes a 64-bit application.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 04-03-2011, 12:15 PM
Hi!
I haven't even heard of rewired, I must check it out :)
I'm running on vista 32-bit.
Old 04-03-2011, 02:13 PM
TCM's Avatar
TCM TCM is offline
No problem running here!
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 04-03-2011, 05:01 PM
Yes and what is really weird is the mere fact that It's working with my cpu too if I choose admin rights... What is the point. It's the same logic that is with the new IE8 and how it reacts to pro tools 9
Old 04-03-2011, 08:18 PM
Benoni's Avatar
Benoni Benoni is offline
On windows vista and windows 7 it is highly recommended to launch Pro Tools with Run As Admin. So its not that weird.
IK even suggests doing this when using their plug ins with Pro Tools.
I always Run As Admin, and have for years.
set PT to default to R.A.A. if you dont like to Right Click and choose R.A.A.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 04-03-2011, 10:52 PM
zedhed's Avatar
zedhed zedhed is offline
+1
http://en.wikipedia.org/wiki/ReWire
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Adam A8H Monitors
Way to get key switching with Miroslav Philharmonik? gsrokmix Virtual Instruments 4 06-12-2012 02:22 PM
Miroslav Philharmonik problems/PT 10 bonzerboy General Discussion 5 03-12-2012 06:55 PM
Problem with Philharmonik Miroslav - DAE Error # 7400 bassplaya07 Windows 6 06-13-2011 01:15 PM
Miroslav Philharmonik? garnoil Pro Tools TDM Systems (Mac) 22 03-15-2009 08:11 PM
Miroslav Philharmonik wernerbachmüller Virtual Instruments 1 09-18-2006 07:35 PM
