Old 09-21-2004, 12:56 AM
tj_davies tj_davies is offline
Default Multiple playlists at once?
Just wondered whether there is a way to create multiple playlists at once?
In preparation before recording voice over, I create approx.15-30 playlist for the artist. At the moment, I always have to repeat "create new/duplicate playlist" 15 to 30 times, to get a total of 15 to 30 playlists. So, is there a way to tell Pro Tools to create multiple playlists at once?
Thanks for any reply, even if it's a "no, not possible"!
Tim
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 09-21-2004, 06:57 AM
FajitaTone FajitaTone is offline
Default Re: Multiple playlists at once?
Go through it once and save the session. go to the "get info" of the session file and make it a stationary pad file. Now you have a template.
Ray Trujillo
Freelance Audio Engineer
Old 09-21-2004, 07:31 AM
Bookerv12 Bookerv12 is offline
If I'm understanding you correctly, you can just put your tracks in a goup and the playlists will change all at once.
B
bookerv12
Old 09-21-2004, 08:04 AM
yep
Ray Trujillo
Old 09-21-2004, 08:08 AM
kcurry kcurry is offline
If you select all the tracks you want a new playlist on, then hold down Shift + Option and select New Playlist from the pop-up menu, that's another way to create multiple playlists. That's how I do it anyway...
Old 09-22-2004, 02:46 AM
Thanks guys,
but I need the playlist on one track (therefore the group idea would not work). I also need the proper name of the artist on the track, so creating a template wouldn't work.
Thanks for all your suggestions, I'll just have to carry on creating these playlists one by one. Maybe it could be a small new featrue for an update.
Tim
PT 2020.12.0
Old 09-23-2004, 03:33 AM
Infa Infa is offline
The template still should work.. Just make the template while the name on the track is still BLANK. Then everytime you open that template all you have to do is change the name of the track(s)...
But that is still better than having to make ALL the playlists everytime, AND name 'em too... This way all you have to do is name 'em !!
Old 09-23-2004, 05:09 AM
Vaphoron Vaphoron is offline
Tim
Hi Tim, I'm guessing you want the track named after the artist so that the audio files on the HD will be easily identifiable. If that is what you are trying to do, I may have an idea. You can set up a template session with a track named something like VO with a bunch of playlists with corresponding numbers. Then, once you are finished with the session for the day, just select all the regions starting with VO in the regions bin and use the "auto rename" feature to rename all the regions at once.
- Jason
Old 07-18-2024, 05:40 AM
VincentJacobs VincentJacobs is offline
Obviously slightly late, but good for people with the same question;
option-shift-down arrow while selecting a clip, copy-pastes the clip to a new playlist. You can spam this shortcut 30 times to create 30 playlists.
A trick for the naming is, this shortcut uses the clip name for the playlist name, so you can consolidate a piece of empty space and rename it "Bob take". First track it creates will be "Bob take" and if you keep going it will add numbers: "Bob take.01", "Bob take.02", etc
Can't create/see multiple playlists TheBaron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-13-2010 02:55 PM
multiple automation playlists jeff markham Pro Tools TDM Systems (Mac) 5 10-28-2006 06:06 AM
export multiple playlists lestermagneto Pro Tools TDM Systems (Mac) 6 03-22-2005 11:07 PM
Editing Multiple Playlists pa247 Tips & Tricks 3 03-27-2004 06:22 PM
Multiple Automation Playlists...? knewbee Tips & Tricks 0 12-06-2001 03:00 PM
