Old 07-02-2004, 04:40 PM
sleepingtiger sleepingtiger is offline
Default Plogue Bidule
Hey,
I just downloaded Plogue Bidule and I'm looking forward to giving it a go. I've encountered one small problem however. When I call up a stereo aux track in PT I'm only given the option of mono for this device in the insert section. It just doesn't show up in the multichannel section. And yes, I went into the PB prefs and set the output for stereo before closing it and then opening PT. In fact I followed the instructions given in the handy tutorial that someone has been kind enough to post here and elsewhere. Still no stereo... I've searched the PB forum and found one person with the same problem but he was told to do the things that I've already done to no avail...
Any help out there?...
Thanks,
Take care,
+=G=+
PTLE6.4
Digi002R
G5 dual 1.8 (rev1)
10.3.2
FXpansion
Tascam MS16
Pro Tools Ultimate 2024.6
Dell 7820 - dual Xeon 6132
64 gigs of RAM
Windows 11 Pro for workstations
HD Native PCIe
Lynx Aurora with LT-HD
Apogee
Mytek
Old 07-06-2004, 10:13 AM
mindnoise mindnoise is offline
Default Re: Plogue Bidule
Hi check this one:
http://duc.digidesign.com/showflat.p...rt=&PHPSESSID=
regs
corrected link
last: PT11.3.1
Old 07-06-2004, 02:18 PM
Hey,
Thanks for the reply but I don't understand why you would refer me to the DUC reply section...
Take care...
64 gigs of RAM
HD Native PCIe
Apogee
Mytek
Old 07-07-2004, 12:11 PM
SORRY!
got the wrong copy and paste
the link is now corrected
best
last: PT11.3.1
Old 07-07-2004, 09:18 PM
Hey,
Thanks for clearing that up ...
Actually, I've already gone through these instructions a few times. (it's very nice that someone would take the time to post them as such, and I thank you for directing me back to them...) Still, to no avail... Everything seems to work fine, I'm even able to rewire Plogue Bidule to Reason in stereo with Reason as the master. It just simply doesn't appear as a stereo instrument in Protools. I've tried everthing that I can think of and the Rewire stereo preference is definitely checked...
Not a big deal at all. It would just be fun if it worked...
Take care,
64 gigs of RAM
HD Native PCIe
Apogee
Mytek
Old 07-16-2004, 06:22 PM
Simon666 Simon666 is offline
So ... in Plogue preferences, rewire section, you've got the "ReWire stereo channels" box ticked ? Just checking ..
Old 07-16-2004, 06:36 PM
Hey,
Yeah, the "Rewire Stereo Channels" box is definitely checked. I even cleared Plogue Bidule from my machine and downloaded it again and followed the instructions from the above link again (I followed them thoroughly the first time around) and the result was the same. Like I say, every other aspect seems to be working it's just not showing up as a stereo option in Protools. It does show up as a mono instument however. I also did all of the maintainance type things that I could think of (trashing PT and PB's pref, trashing Digi volumes, etc) and the result is still the same...
I've been a bit overwhelmed by a production schedule since I first posted so I still haven't had a chance to experiment further. I can't wait to check out Plogue Bidule, even if it's in mono it still looks like great fun!...
Thanks for the reply...
64 gigs of RAM
HD Native PCIe
Apogee
Mytek
Old 07-16-2004, 09:13 PM
Hmm strange ....
I wrote the instructions you're referring to above, and that's about the limit of my PB knowledge - I've only gone as far as using it as a Rewire slave. All fine here as either multichannel or multi-mono insert.
I'm on 10.3.3 and PT LE 6.2.3, so wondering if some problem has appeared in either the PT or OSX upgrade ? If someone else has it working fine on 10.3.4. and LE 6.4, then post here.
The only other suggestion i have (though you might have done it this way already) is to check the 'Rewire stereo channels' thing while Plogue is in standalone mode, i.e. Protools is not running.
otherwise, i'd just suggest a new post on the Plogue forum ... they're pretty quick to answer and may have discovered a new solution.
Old 07-16-2004, 10:46 PM
Simon,
Thanks for the response and also for going to the trouble of posting helpful instructions online. Very kind of you...
I have a feeling that it's possibly a 6.4 issue. There's actually a post on the PB forum from someone else who seemed to be experiencing exactly the same thing. The responses were the same suggestions that you've given me. I haven't checked back in a few days to see if there has been any further discussion. I'll go there as soon as I finish typing this...
And yes, I opened PB in standalone mode and checked the box before opening PT. At one point I actually did that immediately after trashing the PT prefs and volumes and then I restarted the computer... Still the same result.
Thanks again and take care,
+=G=+
64 gigs of RAM
HD Native PCIe
Apogee
Mytek
Old 07-18-2004, 07:33 PM
Hey Sleepingtiger, I see you got your answer :
http://douzo.pair.com/~plogue/phpBB2...b2f002ecf493db
So, UNCHECK "Rewire Stereo Channels" in the Plogue preferences (Rewire), click the apply button, re-open and THEN check the box again.
Do you need to do this every time you load Bidule, or just once ?
I'm still on PT 6.2.3 but updating soon ...
Thanks!
Anyone know how to setup Plogue Bidule in PT8? hwalker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-28-2009 05:25 PM
Plogue bidule woodsdenis Pro Tools TDM Systems (Mac) 14 05-14-2009 07:17 PM
Plogue Bidule won't work with LE 6.7 drthfdr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-18-2004 11:34 AM
Plogue bidule - please help ! Simon666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-30-2004 11:40 PM
Spoke too soon (Plogue Bidule) who 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-21-2003 02:26 PM
