delay between audio and midi tracks
im having a problem when i record midi tracks in a session that already has audio tracks. say i record some guitars and then record some midi drums and then quantize the drums, the drums are significantly behind the guitars. if i change the buffer size, then the lag between audio and midi changes as well. i have the midi playing out of pro tools through my yamaha s90 and back in to pro tools on an aux track. im using 6.9 on a g5. i know there is no delay compensation in pro tools but i didnt think that would cause a problem with midi. if i do a whole session with just midi everything is fine, and if i do a session with just audio everything is fine. if i mix both in one session i get this problem. if its not possible to use midi and audio together in LE, then that pretty muck makes LE useless to me.
Imac Late 2013 2.9 GHz Intel Core i5 8 GB 1600 MHz DDR3 OS 10.11.2 PT 12.4.0 |
midi track record turns off all other midi/instrument tracks delay comp | holyspicoli | Virtual Instruments | 4 | 07-18-2013 06:14 AM |
Delay when bouncing external MIDI tracks to audio | elvolutionstudios | macOS | 0 | 06-15-2012 09:27 PM |
delay between audio and midi tracks | weezerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-12-2006 10:26 PM |
delay with audio tracks | michaelblount | Digidesign Hardware & Software | 0 | 02-05-2004 01:08 PM |
delay with audio tracks | michaelblount | Digidesign Hardware & Software | 0 | 02-05-2004 01:04 PM |
