Old 01-06-2002, 01:11 PM
MrMike MrMike is offline
Default MIDI track and click syncing
I have used my Boss drum machine to put a MIDI drum track down. I later used the Click feature of PT to add a click track. How do I get them to sync up?
thanks
Mr. Mike
we all must answer to the invisible whip - Rasaan Roland Kirk
Old 01-06-2002, 01:36 PM
Roy Howell Roy Howell is offline
Default Re: MIDI track and click syncing
I think it's that you don't have 'Low Latency Monitoring' checked under the 'Operations' column at the top of your sesh. Try it...
rh music
Old 01-06-2002, 03:45 PM
RolandK RolandK is offline
I don't think they will sync up, at least on my yamaha dtx2 it won't. I just turn down the click on the drum machine and use the digi.
Old 01-06-2002, 04:30 PM
Thanks RolandK, if they won't sync on your yamaha, I guess you have to choose one and go with it...
rh music
Old 01-06-2002, 04:37 PM
jbr jbr is offline
Does the Boss drum machine sync to Midi Beat Clock? Look under the MIDI drop down list and choose MIDI Beat Clock..there you will find the settings.
Hope this helps!
Old 01-07-2002, 05:11 AM
mlemos mlemos is offline
MrMike,
I have a Boss Dr-770 and I use the click all the time without any problem. Are you using the drum machine to play the click or are you playing the midi drum track off of the drum machine and the click off of another midi device?
Also, are you sure that your drum sequence is starting at the beginning of a measure and not somewhere in the middle?
Marc
syncing click to an imported track abbiehuxley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2008 08:15 AM
MIDI track not syncing - HELP charlzm MIDI 8 10-12-2006 08:00 AM
Syncing midi drum machine to RTAS Click Track espada3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-11-2005 07:58 AM
RMX drums not syncing with internal click track magilbert MIDI 3 08-01-2005 02:47 AM
Midi click not syncing - how do I fix this? LTEtabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-10-2001 08:28 PM
