Old 03-21-2011, 08:26 AM
oldjohn oldjohn is offline
Default Tube Preamp (ADA MP-1) in 11R Effects Loop
Connection
I set up my MP-1 tube preamp in the 11R effects loop to add an actual, not simulated, tube amp to my selections. I sent the left/mono effects loop output of the 11R to the line input of the MP-1, then sent the A output of the MP-1 to return to the left/mono effects loop of the 11R. I set the effects loop of the 11R to "rack" effects.
Controls.
I set the effects loop to a 0.0 db send and return, then set the mix to 100%. I bypassed the amp in an otherwise clean 11R rig and could move through the settings on my ADA to get different distortions and clean tones. Both units are MIDI controllable, but I have not yet tackled controlling them both with one signal.
Results
This setup worked without a hitch first time out. (Luck). I am now able to A/B a real tube amp with the simulated tube amps. The MP-1 tends toward a thick, 50 watt Marshall sound, but the EQ in the 11R helps to clean that up. My first impression was that the MP-1 does a better job of the "in between" tones, where the sound is not exactly clean, but the distortion is subtle. Sort of like setting a classic amp on 4, where the preamp is pretty clean, but the speakers are starting to break up.
Old 03-21-2011, 09:59 AM
muudrock muudrock is offline
Default Re: Tube Preamp (ADA MP-1) in 11R Effects Loop
I do this with my Egnater M4. Have had similarly good results. Allows me to go direct to FOH and use a monitor on stage. Much better that hauling a 4x12 around.
Old 12-13-2011, 08:00 PM
Johnster Johnster is offline
Oldjohn - Do you have any updates about this? I'm also interested in what you are doing to send midi signals to both the ADA and to the Eleven. And, do you like the clean sounds of the ADA going through the Eleven more than the clean sounds of the Eleven itself?
Old 12-13-2011, 08:14 PM
I had an ADA MP-1 for many years and could never get a good sound from it. I tried hundreds if not thousands of settings. It always sounded thin and harsh to me. The clean sounds were lifeless and dull. The distortion had a lot of gain but was more like a fuzz effect. There was nothing in between for a crunch or overdrive tone that I could get. I did like the ability to switch to any setting via MIDI footswitch but eventually I sold the unit out of frustration with the sound. I am surprised that you like your ADA MP-1 for the exact sounds that I could not get out or mine. Good for you. Keep us posted on how it goes.
Obsidian Dragon
Mac Studio M1Max - 64GB
ER in Tube Preamp Effect Loop phab76 Eleven Rack 2 03-21-2011 10:47 AM
Tube preamp and 001? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-21-2007 04:31 PM
ART MP tube preamp? Ralph K 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-08-2004 03:55 PM
Tube Preamp clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-01-2004 11:05 AM
Best tube preamp for $400-$600 spiritfallrecording 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 02-03-2003 12:46 AM
