add measures How is this done ?
Friends,
Can you add measures to a PT session? I think you can do this. But I don't see any command. I realize it would move my audio but I want to insert more measures into the session. Let's say copy measure 4 up to measure 9 and then paste that into measure 9... How is this done.? Mike |
Re: add measures How is this done ?
Event Menu/Insert Time.
Make sure ALL playlists are showing or else they won't get moved. Also, if you're using Melodyne or Autotune, their data/audio won't be moved so be sure to render first or be prepared to do over. |
Thanks dmazurek... I'll try this. I have been using cut and paste but it overwrites the measures. I want it to "open" up and add measures. I'll do insert time and see what happens.... THANKS for your expert answers..
Mike |
Glad to help.
This method will def work, I do it all the time. |
HOW TO: Skip over measures? | aliaspail | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-12-2017 02:33 PM |
why are there negative measures? | trumpman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-01-2010 06:24 PM |
how to adjust measures | jazzmandan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-22-2004 08:09 PM |
Insert Measures | MusicGuy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-09-2004 01:13 PM |
Negative Measures in PT5? | scottgreiner | Tips & Tricks | 0 | 01-03-2000 09:14 AM |
