In an SC48 how many iterations of a plug in can you use? I know there are only 20 slots but if I want to use 8 iterations (copies) of one reverb can I? Is there a limit and does it vary by plug in?
BTW I watched the webinar about plug ins and this wasn’t mentioned that I noticed. |
Hi.
You can use as many as you want, as long as there's enough DSP resources for that. Besides, some plugins are more DSP hungry than others. In a SC48, you're limited to two mix engine cards (each with 9 DSPs, but some are used for the system). For example, a single TL Space verb requires 2 DSPs. A Revibe requires just one. You have to manage DSP resources in a SC48 or even more, in a Mixrack with just two DSP boards. That can be done by reducing output graphic EQ counting, input channels (if possible), etc. Sometimes, when the DSP limit is close to be reached, the order you place plugins in the racks can affect if you can or can't place more plugins. It's quite easy, I'm sure you'll get the feeling quickly. Merry Xmas! MJ |
![]() Quote:
If the revibe requires just one DSP is that per iteration? So if I want 6 iterations of revibe it will need 6 DSPs? This doesn’t look good because on an SC48 the difference between 16 GEQs and 8 GEQs is only one DPS difference. There are 6 DSPs available with 16 GEQs in use and 7 DSPs with 8 GEQs in use. The problem for me is I am going to need more then 8 and less then 16 GEQs for an install I am looking at the SC48 for. And a difference of one DSP isn’t going to help. |
Hi.
I'm not in front of an SC48 right now, but I have just loaded a showfile created on an SC48 in the Venue Stand Alone, but it doesn't show the exact DSP Usage, only the real console does. In my SC48 showfile I use 1 TL Space, 1 Revibe, 1 Pitch, 1 Echo Farm and there's still some room for some BF 76s, 7 band EQs and a De-esser. In order to achieve this, I had to diminish the channel count to 32 and place things like the over head mikes and two stereo keyboards to the effects returns, which uses way less DSP than the regular processing channels. I'm not sure if you can place 6 Revibes, you probably can, even with 48 channels and 8 Graphic EQs. If you can't, maybe you could use just one or two Revibes and the other 4 verbs could be Reverb Ones or D Verbs, which uses less DSP. I think the SC48 is unbeatable for its price. And the new features, about to come in the future software updates, will make it even better. Good luck. Regards, MJ |
![]() Quote:
![]() I never even tried D-Verb until one day I opened one acoustic demo session that came with Pro Tools DVD and was blown away how good it sounded and then even more blown away once I looked at the mixer and what was used to create that mix. Digi EQ's... D-Verbs... D-Verb has non-lin, room, hall, church, pretty much all basic stuff you need. Come back into channel instead of FX ret if you feel you need to EQ it more than what is available on FX ret. Don't get me wrong, I still run ReVibe, but only one or two and get most of the other stuff covered by D-Verbs, reverb-o-maniac that I am ![]() |
I'm not in front of a console right but now but as I recall it's possible to run 2 instances of Revibe on a single DSP. This means 3 xDSP chips for 6 x Revibes. Sheldon |
I think you are right Sheldon, it is Echo Farm delay that eats a whole chip. ReVibe used to eat a chip off of Mix system DSP chip on Pro Tools systems.
So if I am reading the responses right the DSP usage is per instance.
Is there a chart anywhere that shows the DSP usage for the different plug ins that are included with the SC48. Also is there a chart that shows what the DSP usage of all plug ins are? |
![]() Quote:
![]() Are you looking for a console, or do you already have one? Where/what will this be used for? |
![]() Quote:
I am still learning (as I hope I always will be) for example I don’t know what a TDM plugin is compared to any other type of plug in. I am hoping to do everything we need with what plugins come with the SC48. |
PT 9.06 on Mac with SC48 | Tigerspill | macOS | 0 | 02-04-2013 10:52 AM |
sc48 & Eleven plug-in | dj-mayo@fastwebnet.it | VENUE Live Sound Systems | 4 | 05-16-2012 11:19 AM |
SC48 Plug-ins rack unresponsive during show! | andersf | VENUE Live Sound Systems | 3 | 04-06-2011 08:28 AM |
SC48 into a 5D, Help! | J2sound | VENUE Live Sound Systems | 6 | 03-03-2011 04:56 AM |
Sc48 | braxty | VENUE Live Sound Systems | 7 | 04-02-2010 08:13 PM |
