Old 01-10-2007, 04:25 AM
jackp jackp is offline
Default d verb and d comp
Hey guys when you loaded 7.3 did you lose the digidesign D VERB and the D COMP the eq,s also
how do I get them to load back in to 7.3 Thanks Jack
Mac Pro 8 core Protools 10 HD 4 Accel PCI with Magma, C/24 with 2 192 I/O
Isochrone clock
Old 01-10-2007, 04:35 AM
spkguitar's Avatar
Default Re: d verb and d comp
Digidesign EQ II and Dynamics II are being discontinued. They have been removed from the active plugins list (C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins), but they are still in the un-used plugins directory (C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)), and if you need them they can be copied/moved back into the active folder before starting Pro Tools. DVerb, however is not affected, and should still be available.
EQ II and Dynamics II will, however, no longer be supported (meaning, if they eventually don't work, which is highly likely, you are SOL), so it really is in your best interest to start using the EQ3 and Dynamics3 versions. They are much better plugins anyway.
Old 01-10-2007, 04:33 PM
Hey spkguitar is there a eq 3 in stereo
Isochrone clock
Old 01-10-2007, 04:47 PM
spkguitar's Avatar
You can use the multi-mono versions and they function the same as they would if stereo.
Old 01-10-2007, 05:25 PM
Michael Carpenter Michael Carpenter is offline
I would agree that the plug ins sound better. But i've found the Expander/Gate has a terrible latency which makes it unusable on drums..
MC
Old 10-02-2007, 02:28 AM
estregan estregan is offline
Is there any way to import the plugin settings from EQ2 to EQ3? Or do I just manually copy the settings I have?
-Norman-
M-Audio ProjectMix I/O,PTMP 7.1, A64 x2 3800+, MSI K8T Neo2-F v2.0, 2 Gb RAM, Win XP Pro
Old 10-02-2007, 11:19 AM
tamasdragon tamasdragon is offline
What kind of latency with the gate?
TD
my blog:Tamas Dragon
PSP Master comp, nearest plugin comp to Manley Vari MU? crizdee Pro Tools TDM Systems (Mac) 1 05-22-2007 05:21 PM
Need a killer vocal verb setting for D-Verb tmoc-rocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-21-2005 08:51 AM
EQ > Comp vs. Comp > EQ... when mixing The MPCist Tips & Tricks 9 07-20-2003 09:37 AM
FMR real nce comp. vs ART pro vla comp. Bloux 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-21-2002 10:06 PM
pros and cons of comp-eq or eq-comp dw Tips & Tricks 4 01-28-2001 03:10 PM
