Control Surface for PTMP
Some people may already know this but for those who dont...If you want a control surface for your Pro Tools M-Powered system but are on a budget and can't afford one such as the Command8 or Mackie Control, The Behringer BCF2000 has a hidden Mackie BabyHui preset added to the units firmwear and can be activated very easily with the touch of a button. You can then tell Pro Tools you are using the Mackie BabyHui in the Control Surfaces Setup Menu...Its as easy as that..Hands-on-Control at a fraction of the price...Its has increased my workflow a greatdeal, now I can make slight automation changes without the use of the mouse..A Preset guide is available from their website with all the instructions in Pdf format...I hope this Helps someone and is explained well enough.
Re: Control Surface for PTMP
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
M-Audio Project Mix I/O v The Behringer BCF2000 - wow...a whopping $1050 difference in price.
Be ready to capture the magic... even in your sleep. |
-Norman- M-Audio ProjectMix I/O,PTMP 7.1, A64 x2 3800+, MSI K8T Neo2-F v2.0, 2 Gb RAM, Win XP Pro |
Yeah, that may be true, but the BCF2000 is still the " budget daw controller" as the poster put it. The Project Mix I/O is something I shall consider if I win the lottery
Anyone tried the Kenton Control Freak??
Hey Crate Digger,
Have you managed to turn automation on from the BCF???
New to Maschine and the Maschine Studio Controller? Click below to get started... Maschine Minute Tips FREE VST's for Maschine Blog For Beats Facebook My Twitter |
Yes...once you have activated BabyHui mode, the 'edit' button on the bcf2000 becomes the shift button (2nd fuction button). Then solo's 1-4 (the first 4 buttons under the encoders) become the automation functions (off, read, write and touch) for the selected track...I hope this helps.
Thanks for the original post, CrateDigger...
I wasn't previously aware of the BCF2000's emulation modes so was still looking elsewhere for a decent control surface for ProTools. I've got an Event EZbus which I use with SONAR, but since reading your post and subsequently having a good trawl online for reviews, I now have a BCF2000. It's exactly what I was looking for at a fraction of the price I was afraid it was going to cost... So now I've got a slightly odd setup with an EZbus working as a control surface for SONAR (where most of my virtual synths live) connected via ADAT lightpipe to my FW1814, which feeds into PTMP and is controlled by the BCF2000. SONAR and PTMP are on different computers and linked together by MIDI... If PTMP 7's MIDI capabilities are considerably better than the current version, I might one day be able to drop SONAR completly (Pro Tools is just so much better for audio). With sufficiently long power and USB leads, the BCF2000 is also just about small enough that it's possible to cart it around my studio and maintain pretty good control no matter what instrument I'm in front of. Definitely recommended. |
I believe you press shift+solo3 (to write automation) and push in the encoder that corresponds to the track you want to write to.
003 control surface (As audio) & control 24 as surface | crizdee | ProControl, Control|24, Command|8 | 7 | 01-04-2016 12:30 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
D-Control Es32 Control Surface No Sound from Headphone outputs | mark007 | Pro Tools TDM Systems (Mac) | 0 | 02-08-2012 07:03 PM |
Mackie Control Universal or Tascam 1082 for control surface? | anders | Pro Tools TDM Systems (Mac) | 5 | 05-28-2007 06:12 AM |
Control Surface - Behringer B Control Fader BCF200 | ironfin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-14-2005 10:19 PM |
