How much can Structure load?
I jave a 2.5 ghz G5 with 4.5 gigs of ram and Sturcture won't load any samples past 2.1 gb. Is this a limit of Sructure or my G5? If I add 4 more gigs of ram maxing out at 8 gig, will Structure load more samples?
I just purchased the Structure Symphonic Orch and I can't even get up to the horns when I use 2 articulations of each instrument. Thanks! |
Re: How much can Structure load?
Is disk streaming on? Check under SETUP-> ENGINE.
Busch. |
The 'Max Pre-Load Memory' is limited to 2 GB but if your Disk Streaming such an extreme pre-load would be unnecessary. Buffering can also be set at a respective patch level.
Though with Disk Streaming disabled is the sample content then limited by the Pro Tools shell? filosofem
Aaron Mulqueen - 001 HD Native |
I knew you would jump on this one. When I looked to see how many layers each patch was using, I noticed a horrible graphic corruption once I opened a 6 way round robin string patch. I now believe Structure is 2 gig max per instance. Has anyone loaded more than 2 gigs in Structure? Perhaps more than one instance of Structureis required to build my "Orchestra"? I guess I will also have to stay away from the key switch files and 6X RR files. This is a great dissapointment to me. TDM should take the weight off the CPU and allow for more performance from Structure. Maybe the streaming button shows "on" but isn't really attached to anything? If you start to alter the pre-buffer on a patch per patch level, PT dissapears.... Poof! I would like to think that the new Mac Pro would solve these issues, but PT dosen't even work on Leapord... I'm sure it is time for another Structure update! BTW, My G5 2.5 dual has 4.5 gigs of ram, so I shouldn't hit a 2 gig limit with Structure. If I buy more ram and still have this issue, I'm goona be really mad. |
Hi Rubicon
This is how I'd approach it, I'd knock back the Structure Pre-Load Memory to maybe 500 MB (in fact mines set at 200 MB reading off 10,000 RPM Raptors and I have no problems), save the Structure settings and un-instantiate Structure. Then I'd save the session and reboot. Launch Pro Tools and check the 'Optimize for Streaming Content on Audio Drives' in the Pro Tools Playback Engine settings, load the session, then re-instantiate Structure, loading the Structure settings there after. (The disk streaming option needs to be checked first before instantiating Structure) Now if playback wasn't accessing the HDD samples fast enough, I'd either increase the global pre-load or if I knew that only one patch contained a lot of 'used' Keyswitches I'd increase that patches pre-load buffer. 2 GB of pre-load content is a lot of data and one hell of a session. Either that or a very slow HDD. filosofem
filosofem
Structure Free unable to load homemade files from Structure 1.0 | tuchel | Virtual Instruments | 0 | 04-26-2013 10:10 AM |
won't load structure plug-in | hoodleehoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-14-2010 06:55 AM |
Load sf2 Samples in Structure? | audioplace estudios | Virtual Instruments | 1 | 06-01-2010 08:20 PM |
How do you load a .big sample in Structure? | David Penick | Virtual Instruments | 2 | 01-29-2009 10:56 PM |
Can't load rex files in Structure LE | jazzer61 | Virtual Instruments | 1 | 01-18-2009 07:13 PM |
