Old 03-16-2022, 11:14 AM
BLG BLG is offline
Default Routing folders using Avid Cloud?
Hi. We used Avid Cloud extensively from 2019 until about mid-late 2020 when routing folders came out (or when I discovered them). This screwed everything up since shared sessions would show up without the created routing folders on my collaborator's session. So we abandoned Avid Cloud at that time. Fast forward about 6 months and we thought we'd try again. But when I tried to share my tracks I got a message saying that "Routing Folders will be shared as Aux Tracks". Why, and what does this mean for our workflow? If routing stays the same then I assume the only difference is that he won't be able to collapse the routing folders, but they should still function the same - right?
And BTW, I shared the session, he accepted, I shared the tracks and the upload button never lights up so I have no way of pushing changes to the cloud. I'm going to start a new thread on this.
Old 03-16-2022, 12:11 PM
Default Re: Routing folders using Avid Cloud?
See my reply to your other post. As for Routing Folders, are both of you running the same(numeric) version of PT? If not, I would either do what I suggested in the other thread, or forego folders and stick to simplified routing until its time to mix(the simpler you keep what you share, the easier it will be to achieve success with sharing)
Routing folders don't synch!!?? BLG Pro Tools 14 06-04-2021 02:15 PM
New to PT v2020. A discussion of Aux's vs Routing Folders. Thenewexhibit Pro Tools 2020 18 01-31-2021 08:13 AM
Routing Folders on cloud are shared as AUX Tracks.. WHY? ratava911 Pro Tools 2020 3 11-11-2020 01:43 PM
Have you noticed this with routing folders? DontLetMeDrown Pro Tools 2020 0 04-23-2020 06:12 PM
PT creates empty folders by itself and doesn't allow cloud projects on external drive M-ROX macOS 1 02-27-2020 06:16 AM
