Old 10-11-2016, 12:07 PM
Scotty Chops Scotty Chops is offline
Default 12.6 Mute bug with Groups [SOLVED]
When I make a group inactive in PT 12.6 the mute buttons still act as if the group was active. The only solution is to relaunch pro tools or delete the groups. It also seems to be effecting the solo button, mute button, input, record buttons and if I change the volume with the little volume fader, the channels act as if the group is always active no matter what.
Pro Tools 12.6
OSX 10.11.6
rMBP
Old 10-11-2016, 12:09 PM
Default Re: 12.6 Mute bug with Groups
taking the mute, solo and volume out of the global group settings I'm using as a work around
Old 10-11-2016, 08:48 PM
davemartone's Avatar
davemartone davemartone is offline
Hey Brother. I have decided to stay with 12.5.1
Rock stable.
I am ready to go to 12.6HD.. but after seeing all these weird things.. I think I will hang back.
Any other issues you have found? I have been reading about lots of Clip based fX issues.
www.davemartone.com
Old 10-12-2016, 08:12 AM
Hey Dave, that's really the only one I came across, I don't have an HD rig here so I don't know about the clip stuff.
Old 10-12-2016, 04:38 PM
Question Re: 12.6 Mute bug with Groups
Have you opened a support case with Avid about this issue?
Old 10-15-2016, 03:57 PM
I have not but will do, I assume I can do that under my profile?
Old 10-15-2016, 04:15 PM
Postman Postman is offline
Through your Avid Account.
system specs in profile
Old 10-18-2016, 05:51 PM
problem solved, deleting a bunch of preference files did the trick. Can't believe that slipped my mind to try doing that.
Thank you Avid customer service. You responded quickly and solve the issue.
VCA and Mute Groups - Show on Input/output Screen Howardk VENUE Live Sound Systems 12 04-25-2014 11:08 PM
Mute Groups? jasenj1 Pro Tools 9 2 11-18-2011 11:08 AM
solo/mute in groups PT 8 cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-25-2009 12:58 PM
alternateing mute groups glideman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2008 04:52 PM
Choke/Mute Groups with NN-XT? Morningstar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-16-2004 09:17 AM
