Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 06-16-2001, 05:13 PM
michael c michael c is offline
Default Turning LPs into CDs
I need to record some LPs and turn them into CDs. When I plug a turntable into ProTools through my Neve pres or Avalons, I'm obviously getting an impedence mismatch.
Does anyone out there know the best
and/or easiest way to record LP records into ProTools? Thanks.
Mac Pro 3.5GHz 6-core (6.1 2015)
Monterey 12.7.5
64 GB RAM
1 TB PCIe flash storage
Pro Tools Ultimate HD 2023.12
HD Native Thunderbolt
Old 06-16-2001, 08:06 PM
ppine ppine is offline
Default Re: Turning LPs into CDs
You need to use an RIAA pre-amp, which is built into just about any receiver you can find. Then use the tape monitor or tape line outputs into your pre's, and you should do fine. This should be a line level signal input to your pre's.
If you have alot of albums to do, consider picking up a modern day turntable that actually has digital outs! unreal.. [img]images/icons/smile.gif[/img]
Old 06-16-2001, 08:30 PM
billrog billrog is offline
If you have the Waves plug ins you may also be able to get away with using the Waves Q10 plug in, RIAA curve preset.
Bill.
billrog
Old 06-17-2001, 01:57 PM
You still will not have the proper gain (line level) entering into Pro Tools using the Waves preset. You have to achieve this first.
Old 06-18-2001, 09:23 AM
Thanks..........
Monterey 12.7.5
64 GB RAM
Mbox 2 Not Turning On cegan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-05-2011 06:57 PM
Problems turning on. smfelton ProControl, Control|24, Command|8 5 07-26-2009 04:14 AM
Turning on 003 before or after PC boot? Silence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-11-2009 06:46 AM
Phantom turning off Kroger ICON & C|24 2 03-17-2006 12:19 PM
my 002 keeps turning off, can someone help? onecrackedmind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-27-2004 02:33 PM
