Old 02-03-2004, 08:04 PM
clarpark clarpark is offline
Default fades on muted regions render active fades?! yikes
osx
pt6
g5
hd3 accel
when I apply fades to adjecent muted regions the fades are active. Need I say more? Try this one and let me know if this problem is system specific, I know this didn't happen in os9...
Old 02-05-2004, 10:16 PM
Default Re: fades on muted regions render active fades?! yikes
hello...
Old 02-05-2004, 10:32 PM
JGuth JGuth is offline
same here: g4 dual 1.42, PT 6.1, OS 10.2.8
seems like a bug.
Old 02-06-2004, 01:00 AM
bad jitter bad jitter is offline
Same bug here. But I remember it's always been this way.
HD3, MacOS 9.2.2, PT 5.3.1
Old 02-06-2004, 01:13 PM
DigiTechSupt's Avatar
To the best of my knowledge this is the expected behavior. I’ve had a chance to check it out on a few different versions dating back to 5.0 and the behavior has been the same on all. Any new fade or region created on or between muted regions will be active.
Digi Tech Support
Avid Audio Tech Support
Support FAQ
Old 02-06-2004, 02:18 PM
nevermind only adjacent regions...
ANY muted region that a fade is applied to renders an active fade. causing a nice vinyl'esque effect. This is a bug right? Does anyone consider this a feature?
Old 02-06-2004, 02:25 PM
in the most immaculate sessions this might not be a problem. But after the 6th take is comp'd with the 3rd and 7th take with 70+ tracks and 20,000+ edits this is hardly a feature, I'd call it the mystery wisp and pop gererator, very effective it is indeed. I'd like to see it corrected or selectable as a preference, but who would ever want this option????
Old 02-07-2004, 04:38 PM
I'm going to bumb this thread until someone at digi gives a good reason for this bug that they are calling a feature. It is causing much undue busy work....
Old 02-07-2004, 05:54 PM
I agree it should be fixed-it is counterintuitive behavoir.
Old 02-07-2004, 10:27 PM
dkrz dkrz is offline
I also agree. I should be “changed”...
I also do not like the fact that inverse region muting is no longer working in PT6. In previous versions, if 7 out of 10 selected regions were muted and you applied command M to all of them, the ten regions would swap states to 7 unmuted 3 muted.
dk
www.dpksound.com
How do you get fades to render when you've used X-Form in Elastic Audio? EricWillhelm Pro Tools 9 2 12-10-2010 12:50 PM
won't render fades during playback...? gamblor Pro Tools TDM Systems (Mac) 5 02-15-2009 02:48 PM
Please fix the fades-unmute-muted-regions-bug in groups Frank Kruse Post - Surround - Video 0 06-07-2007 06:02 AM
BUG: PT fails to render fades on the fly Frank Kruse Post - Surround - Video 1 11-09-2006 01:38 PM
Can't render fades: assertion error weberjacob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-04-2003 06:30 PM
