I was using a 192 and a 96...friend o" mine brought over a couple of more 192's he wasn't using (cool friend for sure)...swapped out the 96 with a 192 and got a constant "popping" noise which i was sure was some sort of clocking issue.
Checked the settings...both set to internal...swapped bnc cables...same issue...put the other 192 he brought...same issue...figured...okay...go back to what i had...put the 96 interface back...now THATS doing it!! Everything was fine till i introduced his 192 into the mix...now its doing on my initial setup....When i disconnect the 2nd interface everything is cool and the master 192 behaves fine. Any thoughts??...tried whattever i know ...trashed preferences...cables... Suggestions? ![]() ![]() |
![]() Quote:
Which device is your master clock coming from? the "internal" setting only tells us it is one of them. session setup window cmmd+2 will let you pick which one is the "master clock". Im thinking that one of the clocks is bad (original 192), and that is not the one that you were using before. Switch those settings around and see what happens. Would be rare, but anything is possible once!! ff |
C24 Popping Noises record and standby modes | got2bjab | ICON & C|24 | 5 | 09-28-2009 01:48 PM |
Digital popping noises | llcsi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-09-2007 02:37 PM |
Popping noises 002/MOTU 8pre | felmonk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-22-2007 08:45 PM |
Ripping and popping noises from Reason / Pro Tools | SurroundPro | Pro Tools TDM Systems (Mac) | 1 | 10-26-2004 06:14 PM |
Popping noises | risefan | General Discussion | 4 | 03-07-2004 09:53 PM |
