Old 12-08-2010, 10:22 AM
Skwaidu Skwaidu is offline
Default Can I have both a PT LE 8 and PT 9 install on the same Win7 installation?
Does anybody know?
The LE install would be on its own current license ("tied" to a MBox2), the PT 9 install would come from me updating my separate PT HD system, and this install would be used occasionally with the HD systems iLok license.
Plug-ins would be somewhat irrelevant, I'd be happy even with the plug set currently installed on the LE 8 system (I think)
Old 12-08-2010, 12:27 PM
spkguitar's Avatar
Default Re: Can I have both a PT LE 8 and PT 9 install on the same Win7 installation?
Nope, you can't do it on the same OS install. You can do it on the same machine, but you would need to dual-boot.
Old 12-08-2010, 12:33 PM
Dism Dism is offline
There's also not really any reason to, either.
Your PTHD9 license will work fine with your MBox as well. If you want to run off the MBox, you need only to select it in the playback engine. The only difference is that you would not be able to run any TDM plugs.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Pro Tools 8 LE on Win7 Installation Help Needed BrendanB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-06-2012 07:42 PM
Upgraded to Win7, new PT installation can't see HW leftbrain99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-06-2010 10:47 PM
LE 8.0.4 Installation Failures on Win7 + Solution finches 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-10-2010 03:30 PM
Installation problems - win7 danny1990 Pro Tools SE and Essential (Win) 0 08-07-2010 11:37 AM
Update only works on Installation...cannot perform installation on Win7 xRollinx Pro Tools M-Powered (Win) 5 02-12-2010 07:35 PM
