Old 01-12-2022, 05:14 AM
siuberto siuberto is offline
Default Sending PT Recording in Real Time over Skype or Zoom
Is there a way to record into my Pro Tools and at the same time send the audio to my voice coach remotely? I'm trying to see if there is a way that my voice coach can work with me while I'm singing in real time in Pro Tools. Normally we use Skype but I'm open to trying a different platform such as Zoom, etc. Any thoughts would be welcome.
MacBook Pro, OS Catalina, Focusrite ISA 220, UAD2 Quad, Pro Tools 2020.11
Old 01-12-2022, 07:13 AM
philgrab philgrab is offline
Default Re: Sending PT Recording in Real Time over Skype or Zoom
There is a setting in Zoom, when you are the host, that allows all apps on your desktop to be viewed by your audience pretty solid on a windows-based computer slightly wobbly on a mac. Make sure that is selected and it should work.
Old 01-12-2022, 07:27 AM
its2loud its2loud is offline
Since you’re using a UAD interface you can run Pro Tools and Zoom at the same time and share the hardware.
In Zoom select the UAD as your audio input and output. Turn on high fidelity music mode in Zoom.
There are plenty of YouTube videos out there demonstrating how to do this.
There are also many different platforms to choose from. Such as
Riverside.fm
Soundwhale
Sessionwire
Audio only methods
SonoBus
AudioMovers
Source-Connect Now
Some are free and some are not
System performance might vary depending on your specs
Old 01-12-2022, 08:50 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by philgrab View Post
... pretty solid on a windows-based computer ...
Really? Windows/Pro Tools really freaks if you try to share the audio interface with another app like Zoom. Correct me if I'm wrong.
Click for audio/video demo
Click for resume
Old 01-12-2022, 08:53 AM
The OP is on a MacBook so not really applicable here either way.
I can't speak for Windows experience. I've stayed away from anything Microsoft for the last 15 years when it comes to Pro Tools.
Old 01-12-2022, 09:13 AM
It’s likely it works OK on Mac, just try stuff like that on Macs. Sharing devices/drivers can work on Windows if the drivers are multi-client but it’s much more a crap-shoot, including crossing WDM and ASIO streams. Best not to cross the streams…
Another option on Macs is audio routing software like Rogue Amoeba Loopback: a Swiss army tool for audio routing that I would often reach for for stuff like this. But no need to if just sharing the device works OK for this.
The real thing here is what actual workflow the student and voice coach want, its2loud gave a good list of options to give an idea what is possible.
Old 01-12-2022, 09:30 AM
EGS's Avatar
EGS EGS is offline
Any Windows solution for Zoom & Pro Tools?
Click for resume
Old 01-12-2022, 10:40 AM
Source-Nexus is available for Windows now if you want to send/receive to/from Zoom directly in Pro Tools.
Old 01-12-2022, 11:34 AM
The Weed's Avatar
The Weed The Weed is offline
Source-Nexus as mentioned. SonoBus is free and multi-platform (Mac, PC and Linux), an interface with Loopback built in, an interface with multi-client drivers as Darryl mentioned.
Since I have an RME interface I have a few options as Loopback is built into RME's TotalMix and RME's drivers are multi-client.
I can use the mic input into my interface and set that as the default in Control Panel>Sound>Recording and use that in Zoom or similar as its input.
I can use Pre-Fader Sends to one of my outputs on my interface and Loop that back to an input and set that as Zoom's input. Interestingly, TotalMix allows the use of any I/O for Loopback. For example, I don't have anything connected to my ADAT or AES inputs or outputs, but can use any of them as virtual outputs Looped back to virtual inputs.
Personally, unless the audio I'm sending is "mission critical", I've simply cabled my onboard Realtek soundcard to inputs and therefore into Pro Tools and use Pre-Fader Sends from Pro Tools to an analog output and cabled that to the Line-in on my Realtek and that is the Record default and the input to Zoom or similar.
If the audio is "mission critical" I output to AES use Loopback to AES input and set that as the Recording default. However, given that the audio through browser-based apps like Zoom is sometimes less than high quality, I would prefer to use Source-Connect, Sessionwire or SonoBus in this case.
The Loopback feature also allows me to use Source-Connect or similar standalone rather that use a plug-in within Pro Tools. On Windows I've had issues of squeaks and squawks on the incoming audio from the S-C Link plug-in, thankfully not in my outgoing audio, but not with S-C standalone. Source-Elements' support told me it was a known issue with Windows, said it would be addressed in v4.0 - which has been promised for at least 3 years or more - and suggested I get a separate, inexpensive interface, to be able to use the Link plug-in. Since I'd already spent enough money on an almost $2,500 interface, I looked for a cheaper solution
As always, YMMV.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-18-2022, 01:25 PM
Thanks Darryl Ramm - The real goal that I'm after is for me to sing back a song part to my voice coach and have her hear it with minimal latency. This way she can give me feedback. I thought that if I was able to do record my part into Pro Tools at the same time, how wild and awesome would that be? There must be Pro Tools users out there that are doing this. Now that I am being more specific, is this still possible?
Newbie: Recording off Skype (or anything else) hootdad FireWire & USB Audio Interfaces (Win) 2 05-08-2015 03:00 PM
Real-Time Bounce to Disk...REAL PAIN Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 201 07-26-2010 08:12 AM
Real-time MIDI recording problem.... Hendrix_forever 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-06-2007 07:13 PM
Real Time Pattern Recording in Strike style editior LoadedQuestions Virtual Instruments 4 10-03-2007 10:20 PM
Recording plugin effect changes in real time? darebear Tips & Tricks 1 11-17-2006 07:56 AM
