WTB: Magma PE6R4 Expansion Chassis
Found my PE6R4. No longer looking, thank you!
Thank you!
Michael Lewis The Song Mill Coeur d'Alene, Idaho Last edited by MichaelLewisMusic; 07-21-2012 at 02:08 AM. Reason: No longer needed |
Re: WTB: Magma PE6R4 Expansion Chassis
PE6R4 is an older version. This is an obsolete model. The newer version is PE6R4-I model. PE6R4-I, here is the video http://youtu.be/qBkgiUKIvqs Here is a video showing the differences between PE6R4 and PE6R4-I http://youtu.be/_rgtdr3bnTk |
Thank you Xmen -- so I've heard. Other than the type of cable, I don't really see the difference? I also haven't heard anything that would make me think it won't work with my system (2008 Harpertown) just as well as the newer one would. If you know any details to the contrary, I would appreciate hearing it.
And did you have one you wanted to sell? Thank you! Michael Lewis Quote:
Michael Lewis The Song Mill Coeur d'Alene, Idaho |
I have one but I dont know what Model it is? How do I tell?
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
There should be a model number on the serial number identification plate which is probably on the back or the bottom of the unit.
Michael,
both models will work just fine, the only difference between them is the host card and cable. The PE6R4-I is the newer one but the older PE6R4 is the one Digidesign (Avid) approved officially. I once had the PE6R4-I and it worked great. Just make sure your HD core card is NOT a revision K card as this one would need fixing from Avid which costs several hundered dollars. The revision K cards throw DAE errors -1115. See this thread: http://duc.avid.com/showthread.php?t=291518 Oliver |
Thanks again! Michael
Oliver |
PE6R4, its host card is x4 http://youtu.be/_rgtdr3bnTk ***New PE6R4-I , the I stands for Ipass 1. One Ipass cable, 2. mezzanine card (with one X4 port) 3. X8 host card ***Old PE6R4 1. two Infiniband cables, 2.mezzanine card with two ports 3. X4 PCIE host card |
FS: Magma Expansion Chassis PE6R4 (Denmark) | Peterjk | Buy & Sell | 4 | 07-09-2012 09:33 PM |
Magma Pe6r4-i Epansion Chassis | tvent | Buy & Sell | 0 | 06-09-2012 11:41 AM |
Anyone Run PT 8 TDM with the Magma PE6R4 Expansion Chassis | kd_special | Post - Surround - Video | 4 | 09-23-2010 06:26 PM |
Bugs with Magma PE6R4 Expansion Chassis | [email protected] | Pro Tools TDM Systems (Mac) | 3 | 07-06-2007 12:04 AM |
Digidesign distributes Magma PE6R4 Expansion Chassis | Dutchmuzik | Pro Tools TDM Systems (Mac) | 6 | 03-23-2007 07:22 AM |
