  #21
Old 03-30-2023, 12:08 PM
Eric Lambert's Avatar
Default Re: Missing plugins with new 2023.3 version
Originally Posted by admiral_pancake View Post
Brother, it is so....SO rare that I google a problem and get a solid, usable and functioning answer so quickly. Bless you.
Bless YOU for joining the forum to say so. I'm glad it worked out. Avid could stand to make this a little more clear in the future since it's been popping up quite a lot.
  #22
Old 03-31-2023, 04:36 AM
galetter galetter is offline
Originally Posted by BScout View Post
Yes. You need silicon native plugins to use Pro Tools native on silicon. That's up to you. Avid Link will install the Avid ones. This has been covered in multiple threads since January. One actually has a sticky in the forums. Welcome to 3 months ago.
I reinstalled the same dmg files that I was using while on Rosetta. In most cases, I did not need to hunt down new silicon native installation files as you say. The clean reinstall seemed to work.
This is why it is irritating. I can understand new installs for silicon only but when the same version works when you reinstall, then that's on Avid.
Thank you for your comment but don't bother responding if just going to be negative!
  #23
Old 04-03-2023, 06:07 PM
glynnp glynnp is offline
Originally Posted by Eric Lambert View Post
PT now loads the Silicon version by default so what's probably happening is you've opened PT and all those plugins are not yet Silicon ready so they're absent from the list. Get Info on the ProTools app, select Open In Rosetta, open PT and you should see all those plugins again.
Thanks, Eric! Worked for me.
  #24
Old 04-03-2023, 10:40 PM
Gary Bruckner Gary Bruckner is offline
  #25
Old 04-03-2023, 10:42 PM
I was having the same problems with the new ProTools version and Plug Ins.
Thanks so much for your insight Eric that fixed the problem!
Gary
  #26
Old 05-04-2023, 11:07 AM
JeremiahMack JeremiahMack is offline
I scoured the internet for nearly an hour about this issue and this saved me! Thank you so much!
HTML code is On
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
missing plugins - missing subscription pt12 jazztronauts Pro Tools 12 0 02-23-2016 09:38 AM
Plugins missing in drop down list, but in plugins folder ?? mixingmadness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-12-2007 10:27 AM
H949 MassivePack Version-Missing in Ver.6.9.2 JFK StudioDude Pro Tools TDM Systems (Mac) 6 06-05-2005 12:40 AM
