Hi All,
I just installed Tiger and upgraded to 6.9.2. I opened a few massive sessions and all seems to be working well so far. However my version of the Eventide H949 plugin (MassivePack Version) is not showing up in my plug-ins list, but it does "appear" to load when I launch ProTools. DIGI, is there a more current version of the H949 plug-in other than version 1.13 (which I am using). Is it compatible with 6.9.2 ? Thanks. JFK |
I'm not aware of any version more recent than 1.13 (the last one I posted on the MassivePack downloads page), but make sure you are using the MassivePack version from that page:
http://www.digidesign.com/download/massivepack/ You probably are, since it worked previously. Quote:
http://switch.eventide.com/ubb/showf...rks&Number=946 But it doesn't sound like you are having a problem with authorization, since it seems to be loading on startup. Also, this doesn't sound like the problem since you are opening previous sessions, but the H949 will not show up if you are trying to use it in a 192k session: http://www.eventide.com/plugins/compatable.htm This is the first that I've heard of a problem with the MassivePack H949 and Panther. Hopefully someone else with 6.9.2 and the H949 can chime in here.
Administrator Avid Pro Audio Community |
I'm on 6.9.2 on 10.4.1 - H949 MassivePack3 version is working fine on my machine... I just installed it from the original MassivePack3 CD I believe...
same thing happened to me when i upgraded. i lost stylus rmx and H949.
all i did was reinstall the latest ver. of both plugs(which i was already running) and everything came back up. hope this helps. zeeman
MAC OS 13.5 Mac Mini M1 16gig Ram PT 2023.9 Lynx Aurora 16n Thunderbolt |
Actually after reading the previous post I want to add that I didn't install Tiger OVER Panther but instead performed a clean install. So I had to reinstall PT and all the plugins with it which makes the above post a good suggestion to try.
Thanks everyone.
I too did a clean install of TIger. I will try your suggestions and re-install Ver 1.13. On a side note my Stylus RMX was working straightaway. No Problems with that one. And thanks digi for jumping on this really quickly. It's appreciated. I'll let you all know how it turns out with the re-install of H949. Cheers, JFK |
![]() Quote:
Eventide H949 Promo (and Legacy bundle) leaves 2 components in the Library folder, so when You did a clean install and just move your Plug-In folder its clear that H949 Promo won´t work. BW |
Eleven TDM works, but RTAS version missing - PT8 | Studio Dweller | Pro Tools TDM Systems (Mac) | 5 | 12-24-2008 01:23 PM |
weirdness + Functions missing with M-powered version | LeGato | Pro Tools M-Powered (Mac) | 4 | 05-24-2007 09:30 PM |
H949 UB Installer??? | zeeman | Pro Tools TDM Systems (Mac) | 4 | 05-05-2007 03:05 PM |
H949 with MIX systems | Pietari Koskinen | Pro Tools TDM Systems (Mac) | 1 | 10-02-2006 12:54 AM |
Eventide H949 for Panther & G5 | Avid | Pro Tools TDM Systems (Mac) | 0 | 11-24-2003 09:13 PM |
