I am trying to record to inst track. But I want to preserve the parts I alraedy recorded. So no erase. Thanks.
Win11 Pro Intel i7-12700K @3,6GHz, RAM 32GB UAD Apollo and pre-amps, Pro Tools 2023 lots of plugins |
Are you talking about recording MIDI on top of a clip you previously recorded?
In order to do that, you need to enable MIDI Merge, which can be found on the transport bar. From the manual: The MIDI Merge button, located in the Transport window, determines how MIDI is recorded when overdubbing or punching in. When MIDI Merge is on (Merge mode), recorded MIDI is merged with existing track material. When MIDI Merge is off (Replace mode), existing data within the punched clip is replaced by the newly recorded material. |
Remember that Instrument tracks also can record multiple Playlists. They just cannot be auditioned as easily as possible on Audio tracks. Another easy work-around is to cut/paste existing midi onto un-assigned midi tracks used as "place keepers"
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
You could always put the midi pieces you want to keep on an actual MIDI track and have that feed into the VI via an Instrument track and then overdub on the actual Instrument track. This way you preserve the MIDI information you want without accidentally overdubbing on top of it. Consolidate when you have the pieces you want.
Disabling MIDI patch changes, when recording MIDI through the Eleven Rack? | amnesian48 | Eleven Rack | 2 | 04-07-2014 01:58 PM |
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 | Michaeldante | MIDI | 3 | 03-27-2009 05:42 PM |
Midi recording - I hear no audio, I am new to midi recording | Peter Roberts | MIDI | 13 | 08-19-2007 03:15 PM |
Digi, When Protools creates MIDI regions after recording MIDI info.... | Mt.Everest | Pro Tools TDM Systems (Mac) | 0 | 07-21-2001 12:12 AM |
MIDI Recording in Win98 Protools LE and keyboards...Can I use non-General MIDI sounds | Shan Plourde | General Discussion | 2 | 01-18-2001 08:34 PM |
