Old 01-18-2023, 03:10 AM
LuisT LuisT is offline
Default Can't select Marker - PT 2021.12.0
Hello !
I have a strange behaviour on my PT.
The problem is : when i click on a marker, the playback blue arrow does not follow.
I use PT since 10+ years and never had that.
I tried to create a blank session, same problem.
Link Timeline and Edit selection is enabled.
Play Start Marker Follows Timeline selection is enabled in the preferences.
If i want to select the marker i have to go to the memory locations which is annoying for fast work.
Any idea anyone?
Could it be version related?
If i go the the audio/region part i can select what i want. But if i select, let's say 2 markers with shift, nothing happens. And if i select a marker, nothing happens.
Thanks
Old 01-18-2023, 06:16 AM
WHelbsing WHelbsing is online now
Default Re: Can't select Marker - PT 2021.12.0
Maybe Dynamic Transport?
Old 01-18-2023, 11:36 AM
How can i turn off dynamic transport?
To check if that could be this or not.
Old 01-19-2023, 12:29 AM
Right-click on play-bottom shows the status of dynamic transport.
Old 01-19-2023, 02:47 AM
i checked and dynamic transport is disabled. So i don't know what else it could be.
Old 01-19-2023, 03:18 AM
Well, the hard way:
Download PT Pref Trasher2
https://petegates.com/pgptprefs.html
Make a backup from Your current prefs.
Delete all preferences.
See, if it works now.
If not, restore Your former prefs.
If yes, adjust them from scratch.
(Pro Toos must be quit before using trasher).
Good luck.
Old 01-19-2023, 11:04 AM
i am now mixing a project but will try this later. Thanks!
Old 01-30-2023, 05:12 AM
i trashed prefs with PT prefs and still no change. weird. I don't understand.
Maybe its related to the version or PT i am using?
Old 01-30-2023, 05:33 AM
its2loud its2loud is offline
Please provide your system specs. Namely whether your on Windows or Mac at what version OS.
Old 01-31-2023, 02:36 AM
Mac os Mojave 10.14.6 with a Mac Pro.
Pro Tools 21.12.0.97
2021.6 Clips/Markers Grid Select Broken the.engineer Pro Tools 1 05-26-2022 02:26 PM
Updated to HD Driver 2021.7.0 yet still no HD Native available to select for output Focuret Pro Tools 13 12-08-2021 06:26 AM
Updated to HD Driver 2021.7.0 yet still no HD Native available to select for output Focuret Pro Tools HDX & HD Native Systems (Mac) 0 12-06-2021 07:25 PM
shortcut for select to next marker Neale Eckstein Pro Tools TDM Systems (Mac) 7 10-01-2015 07:36 AM
Keyboard shortcut for jumping from marker to marker... shotgunndunn macOS 1 11-28-2012 07:45 AM
