Old 07-26-2000, 02:10 AM
jack2cannon jack2cannon is offline
Default importing MPC 2000xl midi file ?
HI iv'e been trying this for weeks now and still no luck
I sequence on an MPC and i want to import those sequences into pro tools.
I've tried this with floppy and with zip drives stil no luck.
So lately all i've been doing is recording my MPC stuff in as audio, but i'd rather sketch out an arangement on the MPC and then ad to it from pro tools.
I've done a search on this topic with no luck, i'd realy like to hear from someone who has actually got the MPC to work with DIGI 001.
Old 07-26-2000, 05:33 AM
naman naman is offline
Default Re: importing MPC 2000xl midi file ?
Hey jack -
I'm using a program called MIDI Typer. It works great.
You can download it at: http://www.hitsquad.com/smm/programs/Midi_Typer/
Good luck!
Old 07-26-2000, 07:39 PM
Hey naman.
Thank's for the link, i'll check it out tonight hope it works.
And Breezness,
I'm using a MAC G4 400
Do i understand you right in that the midi file import only works on PC ?
Old 07-27-2000, 12:49 AM
BreezNess BreezNess is offline
Are you on a mac or PC?
If you are on a pc save your midi file to the floppy and import the midi file into Protools.Make sure you remap your midi outputs to your mpc for playback each track to the same channel it was recorded on.
Peace
Breez
I really remember how to SMILE....: )
Old 07-27-2000, 11:14 AM
kazper kazper is offline
you could buy a floppy drive
Or record the midi coming out the MPC
into protools...
I do rember something like PT can't do more than 1 midi track at once but I am not sure if this is true..
but anyways assign the drums to midi and set a channel etc... and record away
if needed or wanted set it up so it records a track at a time..
I use a mpc for seqencing and record my stuff 1 or 2 tracks at a time.. thanks to a patch bay.
Old 07-28-2000, 06:20 AM
Hey Naman,
Thankyou sooooo much for the link,
I downloaded it and it worked perfect, i can't thank you enough,
I hope i can return the favour sometime.
Old 07-28-2000, 06:16 PM
aurelio funk dias aurelio funk dias is offline
I Just put MPC 2000 in sync w/ protools and convert midi in audio.My midi i rec always in MPC I never use Protools Midi features.
www.myspace.com/aureliodias
Reading MIDI file from Akai MPC 2000XL ".ALL" file stevedemena macOS 1 12-23-2011 04:38 AM
Importing a midi file Simon Giddings 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-23-2009 07:52 PM
Importing Midi file from DP 5 and other programs drguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-30-2007 09:39 AM
Importing GM Midi File problem Don Geppert Pro Tools TDM Systems (Mac) 0 01-17-2003 08:07 PM
HELP! Midi file importing on G4 sirdavid Pro Tools TDM Systems (Mac) 2 01-07-2001 06:52 AM
