Monitor Suggestions
Right now I have no output monitors for my MBox 2 Mini. I am currenty using Etymotic 6i headphones as my audio source, obviously not ideal. I see that the output is a 1/4" jack, for now should I just setup some of my sroound sound speakers with an RCA to 1/4" jack? Is that a waste, should I invest in decent headphones? Or is there a set of monitors I could pick up that won't break the bank?
Re: Monitor Suggestions
Real speakers are the way to go. How much can you afford? If your budget is really tight, here are some contenders(all these are under $300 a pair)
Behringer 2030A KRK Rokit5 Yamaha HS50 M-Audio BX5 anything less than these is probably not worth buying.
+1 on the M-Audio BX-5's on terms of bang for the buck. If you look into used powered monitors, make sure you try them first. There is usually a reason someone is getting rid of them. This is one area where it might not be wise to skimp. You should also consider room treatment as that will have a significant impact on your mixing ability.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.7 running Protools 2024.6 Mac Studio M1Max - 64GB MacOS 15.0 running Protools 2024.6 |
In Ear Monitor Suggestions | Hopeless and Reckless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-10-2007 05:43 PM |
Large LCD Monitor suggestions | MX | Post - Surround - Video | 2 | 05-10-2007 10:22 AM |
Monitor suggestions | Stoneroses63 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-23-2006 08:21 PM |
In-Ear Monitor Suggestions Please | SamuelAdams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-31-2006 09:22 PM |
Monitor Suggestions Please! | toddamo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 04-16-2002 12:59 AM |
