Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-16-2008, 07:16 AM
timd timd is offline
Default error \"no record volumes disignated\"
System.
Mac osx 10.4.10
pro-tools m-powered 7.1
error message "no record volumes designated"
I am able to playback and edit, thats not the problem.
When record enabling a track the above error message appears.
I have had the advise to delete volume files within application support/ digidesign/ volumes folder.
I have search my entire HD and deleted all volume files found for digidesign.
Furthermore I have re installed my M-AUDIO FIREWIRE 410 audio interace.
This has not solved my problem and is weird as recording the night before caused no problems.
Any help or advise would be very much appreciated as this is cuasing great problems.
kind regards
Tim
Old 01-16-2008, 08:42 AM
joeydego's Avatar
joeydego joeydego is offline
Default Re: error \"no record volumes disignated\"
you need to set your HD to record by clicking on the p and change it to R. Ok I just checked. With PT launched, go to window/workspace and its there.
2012 mac pro PT 2018 Presonus Studio 192
DigiTechSupt's Avatar
Go to the Workspace window and make sure that the drive you want to record to is set to 'R' (for Record) under the 'A' (for Audio) column.
Avid Audio Tech Support
Support FAQ
Old 01-20-2008, 03:17 AM
worked first time.
thanx for your help....it also cleared up the reason for the workspace window appearing when the error appeared.
thanx again.
Old 07-24-2024, 06:17 PM
Sam Ada Sam Ada is offline
Default Re: error "no record volumes disignated"
16 years later this helped me. thanks
Session must be on an audio record volume if permmited set the volumes to R record lionandthemouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-11-2013 01:48 PM
error with record volumes dwayne00 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-04-2006 02:42 PM
Playback and Record Volumes are different - 002 Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-19-2004 04:56 AM
Designating Record Volumes (HDs) Weatherbox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2003 07:18 PM
HELP: No record volumes designated J-S General Discussion 1 04-30-2003 04:16 AM
