Old 11-21-2006, 10:36 AM
andrew haller andrew haller is offline
Default Digitized picture playback problem.
I recently ran into a problem at an ADR stage where the quicktime movie that was given to us, wouldn't play back on the control room monitor, or in the ADR booth. (It would play in quicktime on the P.T. rig though)
I figured it was the way it was encoded, because another show that was digitized by someone else worked fine, so I know it's not a hardware problem.
I want to avoid this problem at all costs in the future.
The curent video card is an Aurora igniter Pro. From what I understand, it only playsback MJPEG A movies
Should I ask the owener to up grade this card ?
I've looked into the Canopus advc110, but from I understand, it plays back through your firedrive only though video editing software, not quicktime. If I need to spot the picture in P.T., how will this work?????
(g4 1 gig,os 10.3.3, pt. ver 6.3, running a d 24 system, yes a d24 system....:)
Any help is VERY MUCH appreciated....
Thanks..
Old 11-21-2006, 02:31 PM
audiogeek1 audiogeek1 is offline
Default Re: Digitized picture playback problem.
Look at getting Quicktime Pro. You can convert your QT files yourself. This is what I do at my home studio.
Mike
Old 11-21-2006, 02:39 PM
minister's Avatar
minister minister is offline
a phone call to the ADR stage would have told you what kind of card they had and what codec was needed. but, yes, as sndgeek says, QT Pro would have converted the codec for you. no reason to 'upgrade' the card...the Igniter Pro works fine.
the Canopus is NOT a better solution, and only plays DV.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 11-21-2006, 07:41 PM
Thank you for the info.
I'll upgrade to at least 10.3.9, then I'll try it out....
Old 11-23-2006, 02:51 AM
tj_davies tj_davies is offline
The Canopus plays through the firewire and needs a dv codec to show the movie. But you don't need a video editing software. There is the AV option you can get, but it is not necessary.
We have the Canopus here and it is working fine, without the need for a video software. Just as the others said - you need Quicktime Pro to convert the movies, if they are not delivered in dv codec already.
Hope this helps,
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
HTML code is On
3d picture playback puffin Post - Surround - Video 5 03-02-2012 08:55 AM
Using second DVI port on graphics card for Picture Playback 110 ohm Post - Surround - Video 3 07-24-2007 02:00 PM
Digitized video gets offsynced by 1 frame Furn Post - Surround - Video 7 03-08-2006 10:26 AM
Digital picture 'Stuttering' on playback kongomush Pro Tools TDM Systems (Mac) 3 06-11-2003 12:54 AM
Sync problems with digitized pictures Brave Noise Pro Tools TDM Systems (Mac) 0 09-09-2001 01:12 AM
