Old 06-02-2021, 07:55 AM
gives's Avatar
gives gives is offline
Default Re: No SRC in 2021.3.1
Originally Posted by bobbyh View Post
Hi All,
Been having the same issue, I've been trying to do a pull down (from 24 to 23.98) all morning. Running 2021.3.1, also tried it on another system with 2021.3.0 still nothing. I was finally able to successfully do it in 2020.12.
Import Pro Tools 2021.3 Release Notes
https://avid.secure.force.com/pkb/ar...611&popup=true
Selecting an SRC pull value in the Import Audio Window will once again use the correct value for sample rate conversion (PT-269035)
^^ regardless of the description of this bug fix, whenever you apply a sample rate conversion in the import audio window, no conversion actually applies it looks like it just reprocesses the audio? Hopefully they fix this soon.
Yesterday I exported a session to 96khz to test something for Source Elements which I am helping with on a beta team and what I did was just exported selected tracks in session which gives you all the options there I believe to convert sample rate etc. It always seems to work for me especially when I either save a copy like this does to deal with issues of files. Also check your preferences and make sure you have the proper ones checked like making sure proper boxes are checked. Also check your session setup window and make sure you have everything correct there for what video project you are on. sometimes multiple videos can cause problems there or corrupt encodes.
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 12-03-2021, 01:51 AM
CHD CHD is offline
I am experiencing the same issue with SRC not working on "Import Audio". No matter what source sample rate I specify the files are imported at their original sample rate, so no speed changes are available (I've been using this feature for speeding up/slowing down audio for almost 20 years). I tried every combination of settings in Preferences with no results. MacBook Pro M1 13" 16GB, MacOS 11.6.1 clean install, PT Ultimate 2021.3.1.
Dmitri A. Chernov
re-recording mixer/supervising sound editor/studio owner
Moscow, Russia
http://www.imdb.com/name/nm2555539/
Old 01-11-2022, 04:12 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Any real world experiences with later PT versions? Has this been fixed?
2020.12 and 2021.3.1 seem to be bugged in some way, and although 2021.3.1 was marked as fixed it apparently broke something else. I'm looking for actual experiences like film to pal conversions.
Old 01-11-2022, 06:52 AM
FritsFlits FritsFlits is offline
Pro Tools 2021.7 (on Catalina) works fine for me, including the SRC
Monitors in 2021 rmccam Post - Surround - Video 30 08-09-2021 07:27 AM
2021.3.1 innesireinar Pro Tools 80 04-22-2021 01:31 PM
Come on! 2021 already. Just issue what’s right. DetroitT Pro Tools 2020 0 03-05-2021 05:35 PM
