Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-11-2022, 07:59 AM
mellotronik mellotronik is offline
Default Carbon Cat6 Ethernet Cable
Hello,
I cut the Carbon ethernet cable (well my cat did), so I need to ask if a special spec is needed or any Cat6 ethernet cable will do.
Thanks!
Old 01-11-2022, 08:39 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Default Re: Carbon Cat6 Ethernet Cable
According to the manual, a standard Cat6 cable should be fine. I don't believe there is a special Cat6 cable. There are different kinds of Cat cables identified by numbers like 5, 5a and 6.
Sent from my SM-G998U using Tapatalk
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 01-11-2022, 09:31 AM
StudioTalk StudioTalk is offline
I immediately replaced mine with a standard Cat6 cable, I hated the one they sent.
Old 01-11-2022, 09:44 AM
thank you!
Old 01-11-2022, 02:33 PM
dominicperry dominicperry is online now
I have a Cat 8 cable!
Actually, I have a Cat 6 and a Cat 8 and I can't remember which is which. One is really flat and small, which is quite handy.
The Ethernet port on the Carbon is only 1Gb/s so any Cat 5 or higher cable will do for short runs (10m or less - probably up to 100m if truth be told).
Frankly, almost anything will probably work. Cat 6 is probably the standard minimum now.
Dominic
Old 01-11-2022, 02:38 PM
One thing to watch out for - the "higher" specs - Cat 7 and Cat 8 - often have huge boots round the connectors, which can be a problem with some machines and switches/routers - there just isn't space to plug stuff in. For example, the two 10Gb/s Ethernet ports on a Mac Pro 2019 are really close together and a huge boot makes it hard to plug two things in next to each other.
All of which points to just buying a standard Cat 6 cable.
I'd recommend buying a branded cable - there's loads of rubbish on eBay that isn't really compliant with standards. Get one from a reputed local chain store (in the UK, that's PC World).
Dominic
Old 01-11-2022, 02:42 PM
Thanks Dominic, the original Carbon cable says Cat 6, that's why I thought about looking for that type, but I preferred to ask, just in case!
https://ibb.co/jW6qz21
DSL phone cable run OR Ethernet cable run stormmusic Post - Surround - Video 9 12-12-2011 09:26 AM
PC ethernet cable length nymo ProControl, Control|24, Command|8 3 01-03-2009 10:15 PM
Where do you connect the Ethernet cable if the DSL Imagine ICON & C|24 1 04-18-2004 11:26 AM
ethernet cable length Armando ICON & C|24 3 06-10-2003 12:22 AM
Footswitcing C24 and Ethernet cable fid ICON & C|24 5 09-11-2002 08:16 AM
