Old 01-13-2022, 10:26 AM
Piotr Kubiak Piotr Kubiak is offline
Default My new LG UP81 TV sync huge problem.
I just replace my old LG 55" with new 70" (LG up81) tv for Video monitoring.
I set the monitor in low latency - games mode and measured the latencies by the "catchin'SYNC" program. I delayed the 200ms signal in Protools and everything is fine ... Unfortunately, not for long. The TV is unsynchronized every 10-15 minutes (up to about 500ms), it helps to turn it off and on. I never had such a problem with the previous one. I have already turned off everything that was set to auto, IQ... This is horror... Has anyone had such a problem?
www.piotrkubiak.pl
Old 01-14-2022, 12:55 AM
Default Re: My new LG UP81 TV sync huge problem.
200ms (5 frames) seems like a lot but not unusual. The biggest offset in my room is 20qf (also 5 frames) (to my projector with an HDMI-splitter in between)
When you say "delayed the signal" do you mean the video sync offset setting in PT or are you actually using a delay or moving your audio? When you say "unsynchronised every 15minutes" you mean after playing continuously for 15min or after working for 15min starting and stopping? The former would be drift and is also normal if your system isn't genlocked but drifting from 200ms to 500ms (almost 8 frames) would be a lot even for an un-locked system). But first clarify what you mean please.
These modern screens are computers as well so it might be possible. The fact that the delay changes without you changing settings would be a reason to abandon it, an offset is not a problem, PT can easily compensate for it.
First make sure you're not missing a setting. Turn off all the weird noise reduction, "fluid motion" and other nonsense "better-maker" settings on the TV. Also: What's you video output card?
PTHDn 2021.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 01-14-2022, 02:46 AM
Yes it is alot. I working on post for over 15 years now, I dont remember how much lag was on my first LCD 42" (that was simply tv and I use it even now in my studio B, I must check), but my last one 55" has 250ms (after turning off all "true black, true motion, true something...."). LG 70up81 (the newest one) has option for games that I use right now and after measurement with catchin sync it is 200 ms. I thing something is wrong with my system becouse it will be imposible to play in games with so high lag! I found some information that that TV in game mode has about 10 ms lag. I have about 10m hdmi cable that is connected to my mac 5.1 with Blackimagic Intensity Pro card.
I mean video sync offset. Sync changing after working (a lot of start/stop) even on the some project in PAL HD. On the exacly some system with old TV it was no problem for 6 years.
I turned off everything, it was alot of. I know it is huge problem that delay is changing without changing setting. Maybe it is a bug in LG firmware. BTW, I working alot with animation and lipsync :)
www.piotrkubiak.pl
Old 01-14-2022, 04:48 AM
Yeah that does seem a bit scary. My LG screen as a different offset for almost every setting you change but then it will maintain it. I'm at 12qf on my LG screen, 20qf with the projector.
Also check that you have the latest BM driver, I remember very old ones had huge offset and issues keeping it.
Old 01-14-2022, 07:34 AM
its2loud its2loud is offline
This could be an issue with your Blackmagic card. Also, what video codec are you working with in Pro Tools?
Like Frank said, 200ms or 5 frames is not a lot. I wouldn’t worry about the amount of latency you’re dealing with. I’d try and fix the fact that it keeps changing. A 10 meter HDMI is a long run fir HDMI.
This could be part of the issue.
Old 01-14-2022, 08:58 AM
HDMI cable can't be issue - It work for 6 years without problem. I use DNXhd 36 LB for video.
Ok so:
1. I upgraded Blackmagic Card Driver
2. I reset TV to factory setting
3. I change HDMI input in TV.
I checking sync every 30 minutes. All day, no issues! I have now 200 ms latency on non game mode (before that I have 500ms). I don't test game mode now, becouse of deadlines. Hope will be ok now. Fingers crossed.
Thanks for Your help!
www.piotrkubiak.pl
Old 01-14-2022, 12:23 PM
thierryd thierryd is offline
10m cable can’t be part of the problem (variable sync) here. Also 10m of cable doesn’t “add” latency…sound through air travels slowly, but signal through a cable is lightning fast FWIW we run 25m unamplified HDMI in some setups with quality cable and it works for HD video. We als run various other setups with HDMI converted and running over SDI or ethernet. Latency for every setup is different, but consistent once set up (PT video sync offsets between 0 an 20 depending on setup).
Solutions for OP are indeed to be looked for in TV and BM drivers as others have mentioned. Of all settings to turn off in the TV (and the list of “enhancement features” seems to grow with every new model), be sure to to uncheck the frame interpolation or motion smoothness modes (if applicable).
http://www.a-sound.com/
Old 01-15-2022, 09:14 AM
Second day and it's still in sync!
I guess the reason was either bug in TV firmware (I reset to factory setting) or Blackmagic old driver. I was sure that HDMI cable is ok. I have two of them: 10m and second 20m for ADR room.
Thanks for your help!
www.piotrkubiak.pl
Old 01-15-2022, 09:16 AM
Glad you were able to get it sorted without replacing the HDMI cable. The only reason I mentioned it in the first place is because I've had issues with long HDMI cable runs in the past. Just all a part of the troubleshooting process.
HTML code is On
HUGE Problem with HD 8.0.4 maybe ADC??? smilerecord Pro Tools TDM Systems (Mac) 0 08-19-2010 08:35 AM
Having a HUGE problem with going from HD1 to HD2 !!!!!!! S.w.A.t Pro Tools TDM Systems (Mac) 7 03-10-2010 07:58 AM
I have a huge Problem!!! please help! moisesgalvan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-15-2008 06:34 PM
i have a huge problem!!! please help! moisesgalvan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-15-2007 04:51 PM
HUGE PROBLEM!!! PLEASE HELP!!!! juneaudio General Discussion 3 12-21-2001 12:45 AM
