Using 2 MIDI controllers in Pro Tools 9.
Hey I'm running pro tools 9 on my computer. I have 2 MIDI controllers hooked up and working, but I can't get them to give me two separate midi inputs. I have an M-Audio Oxygen 25 and a Yamaha MM8. Both run great and i can use and record them, but I don't know how to use the separately in the same pro tools session. I would like to be able to assign each MIDI controller to a different instrument track. Any help would be greatly appreciated!
Re: Using 2 MIDI controllers in Pro Tools 9.
Let me guess. They're both USB, right?
Make sure one is connected to USB Audio Device, and the other one is connected USB Audio Device (2). Input only. You don't need to send to them, unless you want to. This should work in Pro Tools -- this is how it's connected in mine anyway. I had a mess with three midi devices. One runs the old school midi through my Fast Track Pro MIDI (Alesis QS8), one is the Oxygen 61, and the other is a Presonus Faderport (USB) for transport control from the Alesis keyboard since it's on the opposite side of the room. Fortunately I bought the Faderport from Sweetwater and they helped me get all three functioning with one of my DAWs. NOTE: the Faderport does not work with Pro Tools M-Powered, no biggie for me since I don't use PT for midi stuff.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
I have had some headaches with this as well. What seems to work for me is to open the preferences window>midi tab and select NONE as the default thru instrument(have to do this every time you open a session). AND/OR, once I put 2 instrument tracks into record ready at the same time, they USUALLY behave(work from the individual controllers they way you want them to).
When was the last time you updated QuickTime Dave? Pro Tools Preferences are global and are set when a session is closed.
Aaron Mulqueen - 001 HD Native |
Are there Pro Tools 10 compatible MIDI controllers? | EmperorMusic | Pro Tools 10 | 33 | 02-18-2012 11:23 AM |
USB MIDI Controllers With Pro Tools LE 8? | steals | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-07-2010 07:52 AM |
midi controllers and pro-tools, help pls ! | revere | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-13-2008 02:36 PM |
Legacy MIDI Controllers for Pro Tools 6.9 | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-09-2005 07:06 AM |
PRO TOOLS & MIDI CONTROLLERS | dmaxj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-03-2003 02:18 PM |
