#101
Re: Pro Tools 2021.6
except it doesn't intelligently apply this process to track presets, eg a mono plug-in chain saved and applied to a stereo track will result in multi-mono plugins on the stereo inserts - but dragging them off to a mono track, and then back again will make it stereo (if available). Last edited by Tweakhead; 06-24-2021 at 01:08 PM. |
#102
Sent from my SM-G986U using Tapatalk |
#103
Hey everyone, as of today M1 is supported which is awesome! But I noticed that the CPU cores in the "System Usage" window has dropped from 8 cores to 4 cores. I don't have a lot of knowledge when it comes to that stuff, so I am just wondering why that has happened. I know the M1 arcutecture is "different" so maybe the 8 cores was never suppose to be there because PT wasn't supported yet? I don't know lol Just wanted to ask.
#104
I think that what you are saying is how it works now. Just open the mixer window and press the new thunder button for each channel that you want to put on the dsp chips. Sent from my iPhone using Tapatalk |
#105
Pro Tools 2021.6
Amazing how yesterday a 5.1 session in a HDX 3 was going half full and today the same session only uses 11% of host cpu without any DSP going thru the cards.
275 channels full of plugs, like 16 reverbs ( altiverbs, stratus, revibes,) Wow! |
#106
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
#107
https://www.pro-tools-expert.com/hom...eid=3af5b4ba3b
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
#108
https://lukehoward.com/ |
#109
Welp. My install didn't go so well. I've got an HDX2 system and after installing the hd driver and the latest 2021.6.0 my system isn't showing the cards and digitest shows no cards. That's just great.
Edit: Seems like an installation issue. For some reason: sudo kextload /Library/Extensions/DigiDal.kext Works and I can use the device. Uhh.. now how do I make it so I don't have to load it manually every time? Last edited by glogulus2003; 06-24-2021 at 05:04 PM. |
#110
What model of computer are you using? Is it an M1 Mac? If so, the HD Driver isn’t supported yet for M1 Macs, which prevents HDX and HD Native from being used.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
Recommended iMac Specs for Pro Tools 2021.3 (Pro Tools STANDARD) BigSur Compatibility | Spoil the Child | macOS | 19 | 04-05-2021 05:35 PM |
Pro Tools First 2021.3 is out | Netmania | Pro Tools | Intro Discussion | 2 | 04-02-2021 01:26 PM |
